Cv joint pops out of passenger side axle
Old 06-24-2013, 09:58 PM
Pwnmeister's Avatar
Default Cv joint pops out of passenger side axle
So I recently replaced my torn boot on my passenger side axle because it's an OEM axle and there's no clicking sounds. I didn't want a crappy autozone one. Anyways, after removing the axle, I popped out the cv joint to replace with a new OEM boot, replaced the circlip/ring, greased it, and whatnots. Install everything back, and went for a test drive. Going straight and turning left and right is fine. Once I attempt a slow U-turn, the cv joint separates from the axle shaft. I made sure the cv joint was connected to the axle shaft perfectly. I yanked on it, moved it around or like rotated and it wouldn't break off the axle.
Anyone know a way to solve this? If not, I might just buy an aftermarket axle
Old 06-25-2013, 12:47 AM
Marvin1985's Avatar
Default Re: Cv joint pops out of passenger side axle
Pictures would greatly help
Old 06-25-2013, 03:43 AM
fragmare's Avatar
At this point, whatever went wrong has no relation to what you have to do to make it right. Gonna have to take it apart again, recheck and reassemble. How did you install it back in the car?
Old 06-25-2013, 03:53 AM
The Grumpiest
grumblemarc's Avatar
Axles aren't that expensive.
Old 06-25-2013, 04:24 AM
Wahski's Avatar
What's wrong with AutoZone axles? Replaced mine with one almost two years ago and it's holding up fine.
Old 06-25-2013, 05:05 AM
sleepyaccord96's Avatar
aftermarket axles tend to virbate. not all but most do.
Old 06-25-2013, 05:41 AM
instrument's Avatar
Yeah, i've never heard of anyone insisting on oem axles before, seems odd to me.
Old 06-25-2013, 07:00 AM
Lizardslap's Avatar
I got some cheap after market ones there not awesome but they have a lifetime warranty and I have had 1 explode in the 2 years Iv had them
Old 06-25-2013, 07:55 AM
MadVladCivic's Avatar
Where does the separation occur exactly?
1) The outboard joint separates from the shaft? 2) The entire assembly
separates from the tranny? 3) At the inboard joint, the spider/shaft
pulls out of the "cup"? 4) At the knuckle?
1) Install a new stop ring.
2) Install a new set ring and make sure it seats properly.
3) Make sure axle nut is staked or make sure the part is
appropriate length.
4) Make sure the axle nut is staked.
weese841
Honda Civic (2001 - 2005)
08-18-2021 12:45 PM
grjr
08-23-2012 04:12 PM
jmurphy
17
04-05-2011 01:19 PM
ShinotakuX
26
10-18-2008 06:38 PM
Quick Reply: Cv joint pops out of passenger side axle
