Cheapest way to fix cracked exhaust manifold?
Old 06-18-2013, 12:00 PM
Mason Dixon's Avatar
Default Cheapest way to fix cracked exhaust manifold?
1998 Civic LX has a crack in the exhaust manifold. Its very loud on the road and exhaust comes in the vents when I'm stopped.
I was told that the cat is part of the system and is costly to replace. Whats the cheapest way to get my exhaust working properly again?
Old 06-18-2013, 12:10 PM
bgdriver's Avatar
Default Re: Cheapest way to fix cracked exhaust manifold?
buy $30 header from ebay and install.
Old 06-18-2013, 12:37 PM
mikekh10a's Avatar
or looking off the craigslist classifieds for a compatible exhaust manifold
Old 06-18-2013, 12:39 PM
doublezerohatch's Avatar
hit it with a welder at your buddies place . . .. .
Old 06-18-2013, 12:47 PM
sleepyaccord96's Avatar
weld it and search for a used one
Old 06-18-2013, 01:50 PM
street93eg's Avatar
Use E6011 on the manifold since it is cast. This rod works great for this task on a budget. Other cheap method is find a friend with a MIG welder, use CO2 and just some plain wire and weld it back together.
Old 06-18-2013, 01:58 PM
hit it with a welder at your buddies .. use any electric metal melting technology he has . . . arc . . .mig . . .hit that crack
Old 06-18-2013, 02:01 PM
This looks to be the cheapest I can find, would this work? Just bolts up to flange on top of the cat? Is it easy to swap out o2 sensors?
http://www.ebay.com/itm/1-6-HONDA-CI...e59170&vxp=mtr
Old 06-18-2013, 02:11 PM
street93eg's Avatar
As long as the O2 sensor from the factory wasn't stuck on there with cold weld it should come right out. Have had issues like that before on other cars.
Old 06-18-2013, 03:25 PM
It looks like it is screwed in.
Do you usually change the gaskets when doing this?
Just to make sure, mine has the cat right below the manifold. These aren't welded together, correct?
Old 06-18-2013, 03:40 PM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
Cat is part of the manifold,dont weld it because it will crack again, this is a common issue, you can do the header and swap exhaust but i cant remember the year
Old 06-18-2013, 03:55 PM
So with the the header in the above ebay link, I can just sit that atop the cat as shown in this diagram? The header and cat are not one unit and can be swapped out?
Old 06-18-2013, 03:59 PM
have a look at the picture . .. do you see bolts holding the cat to the header ???? Noooo why you ask ???? just like when you look at your car the header and cat are 1 piece . . .look at the picture u posted
Last edited by Former User; 06-18-2013 at 06:32 PM. Reason: Keep discussions civil
Old 06-18-2013, 04:30 PM
bgdriver's Avatar
You will lose your cat with this method. They usually come with all new gaskets.
Old 06-18-2013, 06:11 PM
there is another entire factory exhaust with a separate cat that is supposed to bolt in
Old 06-18-2013, 06:16 PM
Miguel613ekb18c's Avatar
Go to a junk yard pick one up for cheap no more than 40 bucks prolly less if u pull it ur self
Phelaneng
01-22-2019 07:38 AM
RDX2010
10-06-2017 05:59 PM
curtie94
03-24-2011 08:56 PM
98_civic_420
07-22-2004 11:40 AM
Quick Reply: Cheapest way to fix cracked exhaust manifold?
