Bad fuel/air pick up after high rpms.
The car idles fine. If I drive it under 5k rpms it'll be fine. But once red lining or going past 5k rpms and letting off the gas it'll idle very low and stall. When restarting right after that it will idle at 100 rpms and very rough as well and I can hold the gas pedal down and itll just stay at 100 rpms but if i hold it long enough(25 seconds) it will rev back up and idle fine. No cels and got new plugs, wires, cap, rotor, coil, ignitor, fuel filter, map sensor, swapped clean iacv's. Also watched the fuel regulator while idling for a good 10 minutes but no fuel came out of it.
Slammed95civic
88
05-16-2013 08:41 AM
