AC condenser question
Old 06-24-2013, 01:08 PM
tallguy21's Avatar
Default AC condenser question
So i've finally decided to get my ac system all working but when the shop on base hooked it up to vacuum it then charge it, the mechanic noticed that it was leaking somewhere. We checked all of the lines and it seems to be leaking air on the ac condenser.
What's happening is that the bolt that goes into the left side of the ac condenser (as if you're sitting in the drivers seat looking forward) isn't threading into the condenser, so the line moves around.
My question is do I need to buy another condenser due to the threads being jacked, or would I be able to use a different size bolt (i'm assuming bigger) to tighten it down?
Any help on this would be greatly appreciated. Thank you
Old 06-24-2013, 05:37 PM
Retired Moderator
EsotericImage's Avatar
Default Re: AC condenser question
why not just chase the threads on bolt and hole to fix it?
Cost 15 bucks at harbor frieght
Old 06-24-2013, 05:43 PM
SpokaneSpeed's Avatar
As mentioned... Thread Chase, or Heli-Coil - problem solved...
Old 06-25-2013, 07:03 AM
tallguy21's Avatar
I appreciate the help....I figured there was a way to fix that, but the guy that was charging my ac was talking like I needed a whole new condenser. I questioned that and figured there was another way of going about it. Thanks again
dc4drewH
06-29-2007 05:39 PM
john666
09-07-2004 11:18 PM
Quick Reply: AC condenser question
