96 00 civic window fix? unhappy
so i took my drivers side door apart on the 96 hatch and i replaced the glass and all the rubber seals on the whole door... Everything went together perfectly. Well it still does the same thing..when you roll the window UP once it gets 80% of the way close it starts acting stupid again and the back of the glass towards the rear of the car wants to go up and the font wants to stay still which in turn it wants to jump off track.
Whats the secret to owning a 96 00 civic and having fully functional windows?
The only thing i haven't done is grease the tracks..
Re: 96 00 civic window fix? unhappy
i replaced the seals and all door rubbers and glass because PO sealed both door windows shut with clear silicone. to make the car door silicone free i replaced the pass side door as a whole and i changed parts on the d/s
Lube those babies! Silicone spray down the channels every so often will solve it. Honda service tech gave me the heads up and I've never had a problem since.
im lost as to why the glass wants to act up so bad....i will try and lube the tracks today and try that.
not for a manual window... cant even fine manual window regs anywhere but honda local dealer and i found a elcheapo brand on ebay for 47
http://shop.advanceautoparts.com/web...hedFrom=header
only manual window regs they sell are for 4 door sedan. Not coupe/HB
I like the tuna here
I was having the same problem, loosen all the bolts slightly and you should be able to adjust the two on the far left hand side either up or down. I forget which way I adjusted mine, I *think* it was all the way up. You've probably already tried that, but if you haven't, its worth a shot. That and some lube on the track and mine rolls up perfect.
^This.
The holes are slotted for slack in the door frame. loosen the bolts holding the window frame sliders and (if necessary) regulator. adjusting whichever way is needed - snugging down the bolts and testing window up and down until the frame is holding the window evenly across it's full travel without binding.
you could also try rolling up the window with one side of the frame loose - holding it in different places. if it rolls up nicely, tighten down the frame and try to roll the window down very carefully. If nothing binds, your in a sweet spot. if not re-adjust opposite side and try again.
it can be a process getting it in the correct spot
^^ done it and nothing helps.. the tracks have barely any adjust-ability.. maybe 1/16" at most
have not greased tracks yet, it has been raining like a **** here for 2 days. i think i may make a vid and post it here
^This.
^ there is barely ANY adjustment... i mean i did all of the above and it changed nothing...
If you had an EXTREMEly small amount of adjustment needed it would be ok and would work well but i am off by like 1" so this ain't helping me.
Can you give us a picture of where the window stops and then the tracks and how the glass is mounted?
I could help better if I could see what you're working with here.
If you loved me, you'd all sell me your magic cards to me today
had the same thing, bought an OEM regulator from majestic honda and it works fine now.
85 on passenger side and 90 on d/s... guess i may end up buying one... god i hate how honda windows have so many probs... money money money
damn right about that...
have you seen the 48 dollar regs on ebay?! lol i cannot imagine how bad that thing would work.
motorpsycho13
06-06-2013 01:07 PM
sleepyaccord96
16
05-30-2013 12:18 PM
shadow765
09-17-2008 09:47 PM
CRXstress
08-01-2004 01:59 PM
