wheel lug question need answer ASAP [96 lx]
can you put new wheel lugs in without pressing out the hub?
someone i know needs new lugs put in and i am unsure if it is a quick job, slide them in from behind or a shitty job that requires removing the spindle and pressing the hub out...
'Lugs' can be changed easily
Studs, which Im sure you mean, really need to have the hub removed first, and then the studs are pressed out and new ones in.
Re: wheel lug question need answer ASAP [96 lx] (Spade)
ok... then i'll atleast take a look... i would care even if i had to press the hub out but it's 5 degrees here... brrrrrrrrr
Re: wheel lug question need answer ASAP [96 lx] (IC33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IC33 »</TD></TR><TR><TD CLASS="quote">its not quick you need to remove the brakes and all that crap</TD></TR></TABLE>
brakes is minutes... i don't want to remove the spindle and press the hub out...
and yes, i meant the stud...
Re: wheel lug question need answer ASAP [96 lx] (chris c)
welp, they come out without pressing the hub out... if autozone has them i'll know if the go in... lol
they go in without pressing the hub out too... and i had time to stop at the store and buy a new dvd also...
Historyg
02-14-2008 05:49 PM
