Intake Swap...No fuel
I just finished my intake manifold swap. (97 dx with a 98 ex mani) I ran into some trouble first when i put a coolant line in one of the vacum nipples but now i have another. The car will start and idle fine but when i try to give it some gas it just boggs down. Its definatly not getting enough fuel. I am using the y7 fuel rail, injectors, fuel pressure regulater and throttle body of the old y7 mani.
So....y7 with y8 intake mani not getting enough fuel....anyone know how to fix???????
Re: Intake Swap...No fuel (TurboTagTeam)
Maybe you have the starts of hydrolock if you sucked coolant into the engine...
Pull the spark plugs and see if there is any water in there.
Are your Map and TPS sensor correct???
There should be no fuel issues with that simple swap, however the above will make it seem like it!
Re: Intake Swap...No fuel (civic-4-ges)
agreed, if sucked ANY coolant into the engine, that's bad news. If not I would have to say it sounds like a faulty TPS, at least from what you have described.
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges »</TD></TR><TR><TD CLASS="quote">Are your Map and TPS sensor correct???
There should be no fuel issues with that simple swap, however the above will make it seem like it!</TD></TR></TABLE>
bet money that is the problem....either that or injector wires are wrong
Re: Intake Swap...No fuel (dogfood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogfood »</TD></TR><TR><TD CLASS="quote">I would have to say it sounds like a faulty TPS, at least from what you have described.</TD></TR></TABLE>
If your TPS was working before, it is unlikely that. Re-check your TPS and Map sensor. Map is on the same engine sub-harness as the IAT
Correct you are sir! I switched and now it works fine
4 YOU!!!!!!!!
4 YOU!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam »</TD></TR><TR><TD CLASS="quote">Correct you are sir! I switched and now it works fine
4 YOU!!!!!!!!</TD></TR></TABLE>
Good Good, its a common "mistake" or oversight. Glad it worked!
StealthIsKing
04-11-2024 07:27 PM
obligatory
25
01-13-2008 05:25 PM
n2oisfun
03-01-2005 07:10 AM
pornstarSR
08-06-2003 09:01 PM
