weird clunk noise from passeger side when at low speeds and braking???
well ive noticed that i hear this strange clunk noise coming from under the car mostly when im at very low speeds and i start braking...i can almost feel the thud under my feet when i press the brakes but i sometimes hear also it when i make a turn but not often..mostly when im braking at very low speeds, its gettin a lil louder so its starting to concern me....my brakes are warped and i know they need to be replaced but is there anything else that can cause this besides the brakes?balljoints maybe?....thanx
Re: weird clunk noise from passeger side when at low speeds and braking??? (JDM_Ej)
hmmm dont think its the exhaust since its usually when brakes are pressed at low speeds
Re: weird clunk noise from passeger side when at low speeds and braking??? (eg ferio)
U wont believe it but my car does the same thing on the drivers side when im driving slow and hit the brakes its like a creaking sound almost but its gotten louder but i don't hear it all the time just some time i also been trying to figure out what it is
Re: weird clunk noise from passeger side when at low speeds and braking??? (HoodsiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoodsiR »</TD></TR><TR><TD CLASS="quote">U wont believe it but my car does the same thing on the drivers side when im driving slow and hit the brakes its like a creaking sound almost but its gotten louder but i don't hear it all the time just some time i also been trying to figure out what it is</TD></TR></TABLE>
yuup thats exactly whats happening to my car
Re: (J-Star)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Star »</TD></TR><TR><TD CLASS="quote">same thing is happening to my car </TD></TR></TABLE>
that makes 3 of us
that makes 3 of us
Re: (eg ferio)
not that this helps but my friend's oldsmobile does the same thing int he driver side rear. sounds like a clunking sound like some rubber thing is flopping the wheel well.
Re: (Solscud007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 »</TD></TR><TR><TD CLASS="quote">not that this helps but my friend's oldsmobile does the same thing int he driver side rear. sounds like a clunking sound like some rubber thing is flopping the wheel well.</TD></TR></TABLE>
damn that makes 4 im still investigating to see wht it could be can anyone else help me out here?
Re: (ls95hatch)
Balljoint, tierod, but I would mostly say a wheel bearing. It would humm at lower speeds and somtimes creak, and at higher speeds it would be almost non existant
Re: (cnyej1)
i got the same problem
i got all new ball joints, gsr brake swap, added a sway bar, skunk2 camber kit, new tie rods. new axles.
i assume its something loose ima check it out tomorrow afternoon and see whats up.
Re: (cnyej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 »</TD></TR><TR><TD CLASS="quote">Balljoint, tierod, but I would mostly say a wheel bearing. It would humm at lower speeds and somtimes creak, and at higher speeds it would be almost non existant </TD></TR></TABLE>
i just recently replaced the tie rods and the ball joints seem fine butthe way you described the wheel bearing seems like what my car seems to be doing...thanx more suggestions are welcomed
Re: (eg ferio)
well.... im another one.... theres 2 things it could be that i found on my car, since my upper/lower ball joints, wheel bearings, and tie rods are new....
check on the screw in the rotors... are they still there? and also, the brake pad retainers (anti rattle clips) are usually the problems
hope this helps
hope this helps
Re:
hmm, my makes a clunk but under different situations...
if i'm driving slow and i step on the gas, i will hear a clunk, and then when i slow back down i hear another clunk... basically whenever the car shifts from going forward and backwards... it just started making the clunk sound about two weeks ago, it wasnt always there before... it doesnt make any sound on turns or anything
i was thinking it had something to do with the drivetrain? not sure
Ya i would check the axles first.. then i would jack up the car.. and try and move the wheel if the wheels moves back and forth then yoru ball joints are shot.. i saw a guy with some reaaaaly bad ball joints.. have some problems breaking and almost crash..
dude i make the 100th person. JUST TODAY i started drving my civic. and it happened. my brakes need bled, then all of a sudden the pedal felt like it didnt need anything. then i pressed it hard and CLUNK! now its goes clunk everythignt the wheel spins i thought i got a flat. its louder when i put around. its really bugging me. my car is slowing seeming to fall apart
Re: (HoodsiR)
Check CV joints and Hub Bearings...
cost a bit of $$$ to get fixed
Also check your intake piping make sure everything is tight.
Nice sedan! I got one too...
