p1163(air/fuel ratio sensor) code in my 1998 Hx, please help!!!
here is the code:
P1163 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response
Here is the problem:
When i went to a auto parts store to test it, we looked it up on the computer, and it says this car shouldn't even through this code-but duh, it is. It has done this code for the last couple months (4 or so) so its not just because of the cold weather. is there a air/fuel sensor somewhere i should try replacing?
Im just confused because it says on the computer that this code should not even come from this car (this was at a auto zone)
Any help would be great.
Re: p1163(air/fuel ratio sensor) code in my 1998 Hx, please help!!! (92hatchy)
one other weird thing, when i put the jumper wire in, and count the blinks of the ecu, i get 61. I am going to try cleaning out my sensor and see what happens. I read something some time that im supposed to warm up my car at 3000 rpms untill my radiator turns on, then go on the highway and drive for a while, if it turns on, then the sensor is bad. But what else could it be?
I do have a CAI on it, and maybe moisture in the intake tube messes up the sensor. Any input would be very helpful.
ok, i keep on getting this problem. what could be the problem? O2 sensor? or is it the sensor in the air box? please help. Im sick of getting this code, and having to clear it out all the time. When i do clear it out, its fine for like 2 weeks.
01PYTypeR#1140
12-31-2003 10:05 AM
