B18c + B20 block???
B18c + B20 block???
Hi guyz...my Eg is runnin with b18c engine...was thinkin to put a b20 block with it in order to run more fuel...
What do you guys think?
Tanx
Modified by chrissleame at 5:22 PM 12/21/2004
Tanx
Re: B18c + B20 block??? (chrissleame)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrissleame »</TD></TR><TR><TD CLASS="quote">Hi guyz...my Eg is runnin with b18c engine...was thinkin to put a b20 block with it in order to run more fuel...
Tanx
Modified by chrissleame at 5:22 PM 12/21/2004</TD></TR></TABLE>
Your reasoning for going with the larger block makes no sense; however a B20 with a vtec head will run perfectly fine and give you a little more torque if built properly. The downside is the block was not designed to rev as high.
Tanx
y spend the extra $$ and get a b20. just use ur GSR block Sleeve it, Bore it, Stroke it,. The GSR is a stronger block and has the nice oil squirters to help keep the temperature down.
I think you should sell your ride to someone who has some type of a clue, because you obviously don't. Sorry, for being so blunt but damn, bigger block to use more fuel
