d15b vtec swap...alt wire harness doesnt match stock harness
so im almost done swappin in my jdm d15 and the clip on the stock wire harness doesnt match the inlet on my new alt...anyone had this problem with their swap? can i use my cx alt??
any help is appreciated TIA
p.s.- search came up with one thread that didnt help
Re: d15b vtec swap...alt wire harness doesnt match stock harness (ek9800)
i used my cx harness and added vtec an oil pressusre wire and ground everything pluged in to each other fine
you can use your stock altenator. it'll bolt right up. the altenator plug design changed with the OBD generations... but it SHOULD have the right plug on it...
Re: d15b vtec swap...alt wire harness doesnt match stock harness (cxjon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxjon »</TD></TR><TR><TD CLASS="quote">i used my cx harness and added vtec an oil pressusre wire and ground everything pluged in to each other fine</TD></TR></TABLE>
I did the same
I did the same
b20beast978
23
06-11-2007 09:52 AM
Civic97s
07-30-2006 06:27 AM
