b16a3 will it work?
b16a3 will it work?
I can get a b16a3 for cheap comeplete swap out of my friends del sol. I was wondering the kind of problems i will run into in doing this swap.
HT Order of Merit
Re: b16a3 will it work? (yamaha250f101)
Search.
Upper right.. says search.
Short answer: If you are mechanically inclined, its simple. If your not, then better start searching. Use google, and the search feature here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yamaha250f101 »</TD></TR><TR><TD CLASS="quote">I can get a b16a3 for cheap comeplete swap out of my friends del sol. I was wondering the kind of problems i will run into in doing this swap. </TD></TR></TABLE>
Im not gonna flame you cause its your first post, but we need a little more information. For starters, what car would this motor be going into? That will help determine everything that is necesary, and what wiring, etc. needs to be done.
How many miles are on the motor?
it is a 94 civic hatch dx and i was the one who swaped it into the del sol. its got about 110k on it so its used but it still makes good power. it went right into the 94 del sol of his so i think it woudl be easy.
if you swapped it into the del sol, then you should be aware of the fact that it will work. just get everything out of the sol.... linkage, axles, and such
shugahkane
11-11-2006 04:53 PM
