Switching JDM climate control face, with USDM Climate control....Help
Is there a link that shows pics on how to do it? I already have the stock one pulled out but need some help on how to take out the stock face and put the JDM one.
Re: Switching JDM climate control face, with USDM Climate control....Help (BolivianFuego)
Don't have pics but its pretty self-explanatory when you get it out. Just keep taking it apart and you will get to the transparent plastic piece you're gonna replace. Just a few screws and tabs here and there.
Re: Switching JDM climate control face, with USDM Climate control....Help (SiRG EJ1)
Damn just finished up. That damn Heat control cable is such a pain in the ***,til now even when i try to go to full heat it goes back towards cold a little. :shakes fist:
Also my stock control unit at times would sort of turn dim from the middle all the way to the right, by hitting it it lights up. What could it be? I thought it might be a loose connection but now im pissed cause thats not it at all. What could it be?
I posted a topic abut the climate control lghts a while back...here is the link:https://honda-tech.com/zerothread?id=1035789. Hope that helps a bit. I have the same problem still and I haven't got the chance to fix it yet.
Re: Switching JDM climate control face, with USDM Climate control....Help (Vincent.)
Damn this sucks monkey nuts. Same thing happens with me, i evne changed the bulbs. Soem poeple on that threada even went to taking theirs apart and wiggling the wires and waht not. O well sounds like im fucked.
pull it back out and make sure your bulbs are in all the way......b4 putting all back together take the control piece and plug it back into the harness to make sure the bulbs are working.......did this 3 or 4 times b4 i got it right.....
hondaj05
08-24-2006 09:44 AM
naya1civic
08-23-2004 05:36 PM
