OBD2 b16a2 into a 94 civic cx... HELP
OK I have everything just like it would come out of a 99 si wire harness and everything. But I have a p06 ecu... not quite sure what thats from.
Ok im pulling out my d15b8 right now. What all needs to be replaced on the b16a2 to put it in.
I need to know
Wiring harness? Keep new one or old and what to make it work
What is a P06? Will it work do i need a different ecu?
Sensors??? Do I need to swap any of them ?
Im looking for the easiest and cleanest way to do this. All help is apprieciated.
Any missing information also if I am going to run into something later!!
I need to know
Re: OBD2 b16a2 into a 94 civic cx... HELP (Anoyd540)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Anoyd540 »</TD></TR><TR><TD CLASS="quote">OK I have everything just like it would come out of a 99 si wire harness and everything. But I have a p06 ecu... not quite sure what thats from.
I need to know
You can keep either wiring harness. If you keep the OBDI (the one on your old motor that your removing) you will have to rewire the dizzy and altenator. not to hard of a task.
Sorry but the P06 ecu will not work. you need a Chipped p28 or a P30 ecu. the Chipped P28 will not look for a knock sensor. the P30 will
You may have to swap some sensors if they have been damaged. So keep that D15 around for a little assurance incase u have a busted sensor.
If u want more info check out my swap info thread found in my signature.
I need to know
shawnvtecordie
09-26-2017 11:21 AM
v-tec maz
12-31-2005 04:29 PM
white Si
06-08-2003 05:22 PM
civicHBphatride
01-18-2003 02:46 PM
