Gsr Throttle Body on B16a???
Re: Gsr Throttle Body on B16a??? (slambedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">ive got 2 ls bored throttle bodies... they are the same.</TD></TR></TABLE>
so LS throttle body will bolt right up to gsr im without modification?
How much are u asking for?
Re: Gsr Throttle Body on B16a??? (Mr.DC2TurBo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo »</TD></TR><TR><TD CLASS="quote">
so LS throttle body will bolt right up to gsr im without modification?</TD></TR></TABLE>
D, B, and H are all interchangable. The only difference is on some the IACV is attached to the TB and others the IACV is on the Intake manifold.
The stock LS is 58mm
All new DOHC VTECs are all 60mm
Type R is 62mm
B20 is 60mm
H22 is 60mm
D series are all 56mm
Older gen B16s only got the 58mm.
Type R is 62mm
B20 is 60mm
H22 is 60mm
Re: Gsr Throttle Body on B16a??? (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
Type R is 62mm
B20 is 60mm
H22 is 60mm
Not all Ls Tb's are 58 thats just the older ones....... i know 94+ are 60mm also
Type R is 62mm
B20 is 60mm
H22 is 60mm
Re: Gsr Throttle Body on B16a??? (ReDHaTcHy97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHy97 »</TD></TR><TR><TD CLASS="quote">
Not all Ls Tb's are 58 thats just the older ones....... i know 94+ are 60mm also</TD></TR></TABLE>
Forgot to say that.....got too busy listing the others
Is the iavc of the LS on the tb or im? I'm going to be using a 01 LS throttle body with a GSR blox im. So can I transfer ALL the sensors from my stock ls tb and im to the gsr?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo »</TD></TR><TR><TD CLASS="quote">Is the iavc of the LS on the tb or im? I'm going to be using a 01 LS throttle body with a GSR blox im. So can I transfer ALL the sensors from my stock ls tb and im to the gsr?</TD></TR></TABLE>
the IACV(Intake Idle Air Control Valve) is on the Intake Manifold. Yes you can use all of the ls sensors on the GSR manifold.
Re: Gsr Throttle Body on B16a??? (caonima)
how would u make the gsr throttle body with the idle air control on it...... work with the 2nd gen jdm b16a idle air control thats on the intake manifold ????
Modified by Got Milk at 9:20 AM 12/28/2004
Mr. Badwrench
Type R is 62mm
B20 is 60mm
H22 is 60mm
except the cx. it is very tiny
Type R is 62mm
B20 is 60mm
H22 is 60mm
Re: Gsr Throttle Body on B16a??? (boostedcivicsir)
lol anyone at all know im really curious
nefariousyellow
11
12-16-2007 08:41 AM
comptechgsr2000
05-08-2002 04:21 PM
comptechgsr2000
05-08-2002 04:05 PM
