Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page >
How Do You Remove The E Brake Cable Off A Integra For Rear Disk For My Hatch?
Old 05-24-2005, 08:19 AM
Default How Do You Remove The E Brake Cable Off A Integra For Rear Disk For My Hatch?
basically went by the local junkyard today and they had a 90-93 integra with rear disk so im going back tommorrow to pull it off since it only costs $60 bucks for the rear disk conversion and was wondering how to take of the e brake cables since i will need them to swap the rear disk on my 93 VX hatch.
i think the prop. valve is gone but on that one DA but there is another DA there(rear disk is already gone off the 2nd one) and i didnt check that so i should be able to get the prop valve and maybe even upgrade to the BB and MS of the DA.
tried searching too.... thanks
The DX Rex is offline
Old 05-24-2005, 08:27 AM
Default Re: How Do You Remove The E Brake Cable Off A Integra For Rear Disk For My Hatch? (nyhustla2k)
remove the console. under the e brake there is two cables un hook those. there should be 2 10mm bolts. take those off. go under the car and the e brake cables should be run under the heat sheilds. take the heat sheilds off and unbolt the bolts that hold the cables to the body. then you are done
getnasty is offline
Old 05-24-2005, 08:28 AM
Default Re: How Do You Remove The E Brake Cable Off A Integra For Rear Disk For My Hatch? (bottle fed)
sounds good to me, thanks, just needed an idea of how difficult it was.
properlystewed
Suspension & Brakes
05-09-2014 11:58 PM
cheapo23
06-02-2010 09:28 PM
Nisif
06-06-2008 07:43 PM
slo_hatch
04-23-2008 06:08 AM
Mr. Choi
25
10-02-2004 09:03 AM
Quick Reply: How Do You Remove The E Brake Cable Off A Integra For Rear Disk For My Hatch?
  • Ask a Question
Question Title:
Description:
