eg6 sir front brakes
Hey whats up this is my first post but I've been reading stuff on here for awhile (using the search), but some info I could't find is what brake pads to use on the jdm sir front brakes. I bought some AEM pads for a 94 teg part #20-146 and after putting on my new rotors I found that the pads don't fit quite right, the tabs that fit into the clips are to big. If anyone has ran into this problem before please help me out.
Re: eg6 sir front brakes (cmerce)
Well there's your problem right there... Why'd ya buy brake pads that were meant for an Integra...? Correct me if I'm wrong but I don't think oem Integra brake pads will fit on to EG6 brakes... You should have just went with GSR front bakes...
I think it has something to do with the front brake set-up coming from the jdm civic but Im not sure which make/model cross reference.
#1 Super Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmerce »</TD></TR><TR><TD CLASS="quote">On the AEM brake pad box it said that they were for a 92-95 ex and 94+ integra</TD></TR></TABLE>
Does it mention anything about ABS? The civic's & Del Sol's with ABS have the same front calipers as Integras. The civic's & del sol's with integra sized 10.2" front brakes and NO ABS do not have the same calipers. This also goes for the EG6 Civic Sir2 (NO ABS). The pads you need are for a 93-95 Civic EX Coupe w/o ABS (rear drum) or 94 Del Sol VTEC w/o ABS.
Re: eg6 sir front brakes (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">
Does it mention anything about ABS? The civic's & Del Sol's with ABS have the same front calipers as Integras. The civic's & del sol's with integra sized 10.2" front brakes and NO ABS do not have the same calipers. This also goes for the EG6 Civic Sir2 (NO ABS). The pads you need are for a 93-95 Civic EX Coupe w/o ABS (rear drum) or 94 Del Sol VTEC w/o ABS.</TD></TR></TABLE>
the brake master at work again
Endless STi
11-08-2004 11:23 AM
