IACV HELP!!!....Member IVI IM LOOKING AT YOU!!!!
Old 05-23-2005, 09:35 PM
greenlx777's Avatar
Default IACV HELP!!!....Member IVI IM LOOKING AT YOU!!!!
ive got this crazy idle problem with my iacv the same problem that member IVI had in this archived thread he posted
https://honda-tech.com/zerothread?id=972218
can any one help, its urgent......
thanks
Old 05-23-2005, 11:12 PM
hatchish's Avatar
bump cuz i know how it is
Old 05-23-2005, 11:17 PM
9_of_10's Avatar
Default Re: (hatchish)
Gotta luv motor issues. Have you done anything new to the motor prior to having this problem?
Old 05-24-2005, 03:43 AM
EE_Chris's Avatar
Default Re: IACV HELP!!!....Member IVI IM LOOKING AT YOU!!!! (greenlx777)
What's the setup? What car, engine, ECU, additional electronics, etc etc etc....
Have you done maintenance recently and then this started to happen or has it always been happening?
What have you done in an effort to solve this problem? Have you tried cleaning the IACV? Have you messed with either the idle air bypass screw or the throttle plate stop screw?
Old 05-24-2005, 03:56 AM
siregcivic's Avatar
check your iacv unplug it if it doesnt make a difference try to get a new one. if it just fluctuates between 700 and 1200-1300 just ake the throttle body off and spray throttlebody cleaner in everyport in the intake manifold get a new gasket put and clean the throttlebody.
i dont even run a throttlebody gasket but i guess its good to have one. but if you have the problem where you lightly touch the gas pedal and it sounds like you have a governer at 1500 you need a new one
Old 05-24-2005, 11:30 AM
greenlx777's Avatar
Default Re: IACV HELP!!!....Member IVI IM LOOKING AT YOU!!!! (EE_Chris)
the whole story is here
http://www.homemadeturbo.com/f...205.0
but basically i did a mini-me
i have a 98 lx automatic and slaped on a Z6 head with plenum manifold, the whole problem started when i tryed to do the 3 to 2 wire iacv fix, but then realized that it only works with ecu that already have v-tec (p28)
i still have the P2E so then after realizing this, i put all the wires back to the original locations and i replaced the throttle body from the Z6 mani, with my original throtle body with the IACV on it, and blocked off the IACV oles on the Z6 manifold
so now im using the original 3 wire setup andim stil getting a CEL code 14
i dont know what to do???
Old 05-24-2005, 12:01 PM
EE_Chris's Avatar
Sounds like a mess...
I'd just get a Z6 throttle body and put the 2-wire IACV back in place. Graft over the 2-wire connector onto the 3-wire harness. Move the needed pins at the ECU. Use a P28.
Old 05-24-2005, 12:28 PM
greenlx777's Avatar
yeah but then i need to buy a p28 and i need to splice all wires, just for a stupid IACV that should be working
EnviedByMany
10-21-2010 07:23 AM
philep_cb7_91
02-21-2010 11:28 AM
rice a roni
12
05-24-2005 12:31 PM
neXus dc4
05-15-2004 12:04 PM
bdicustoms
06-02-2003 03:47 AM
Quick Reply: IACV HELP!!!....Member IVI IM LOOKING AT YOU!!!!
