Tubes in trunk????
Tubes in trunk????
I Have a 95 civic ec coupe.. where do the tubes that run along both sides come from?(where are they connected to) i think this is wat is causing my leak. I will try to see if it is clogged? Does this tubin come the sunroof or rain gutters ?? thanks
Re: Tubes in trunk???? (honda95civic)
i think this was covered some where before. the tubes are like vents so air can come out/in, so you can close your doors and all that good stuff. that could be a factor as well as taillight gasket, trunk linings,etc.. heres a couple threads that experienced similar problems
https://honda-tech.com/zerothread?id=1190055
https://honda-tech.com/zerothread?id=1202510
https://honda-tech.com/zerothread?id=1115194
https://honda-tech.com/zerothread?id=1160043
https://honda-tech.com/zerothread?id=1111697
https://honda-tech.com/zerothread?id=1072644
if its your taillight gasket you can use this write up as a guide to do your model
https://honda-tech.com/zerothread?id=885253
Re: Tubes in trunk???? (longbeachpurplecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longbeachpurplecivic »</TD></TR><TR><TD CLASS="quote">i think this was covered some where before. the tubes are like vents so air can come out/in, so you can close your doors and all that good stuff. that could be a factor as well as taillight gasket, trunk linings,etc.. heres a couple threads that experienced similar problems
good guy for finding all those helpful links for you.
On a side note i still havent fixed or spotted my leak in my trunk... so i just keep a rag there and whenit rains the next day i just repalce it with a dry one.
Re: Tubes in trunk???? (POE)
yea thanks for finding them links..
and i want to make a custom trunk install.. so the rag idea.. is good but i dont want to bother with that.
i sealed the tails completey.. it was comin in from there before i belive.. i layed in the trunk while my dad hosed down the car.. lol..
now its comin from behind that metal ridge .. near the wheel well..but behind... i have pics..
i might just weld a barrier from the two point.. caulk it up.. and drill some holes.. so when water gets in there.. it will just drain out.. haha..
thanks again..
thanks again..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic »</TD></TR><TR><TD CLASS="quote">yea thanks for finding them links..
Lucky he didnt leave you in there for a while.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic »</TD></TR><TR><TD CLASS="quote">I Have a 95 civic ec coupe.. where do the tubes that run along both sides come from?(where are they connected to) i think this is wat is causing my leak. I will try to see if it is clogged? Does this tubin come the sunroof or rain gutters ?? thanks </TD></TR></TABLE>
You mean the plastic tubes that are behind the carpet that go over the wheel wells? I found mine the other day while I was putting on a set of new shocks. I was like "WTF?"
Re: Tubes in trunk???? (Djaric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djaric »</TD></TR><TR><TD CLASS="quote">
Lucky he didnt leave you in there for a while. </TD></TR></TABLE>
I had my seats out... lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-ex »</TD></TR><TR><TD CLASS="quote">
You mean the plastic tubes that are behind the carpet that go over the wheel wells? I found mine the other day while I was putting on a set of new shocks. I was like "WTF?"</TD></TR></TABLE>
yea exactly them... and they run into a rubber groumet type tube that goes out the car..
