Replace AC compressor? Cost? Retrofit?
Will a 95 complete ac system fit a 92?
OK, so the car had the ac ditched. I'm looking to put it back in. Will a 95 system fit a 92DX? How much will a shop charge me to put it, will they have to retrofit even though it's already a r134a?
Modified by integraXTC at 5:11 PM 5/23/2005
Re: (integraXTC)
well if it allready had ac it shouldnt be that hard to put it back in your self i would say the hardest part will be finding everything you need. then youll have to take it to a shop to get it charged.
incorrect. it is possible your car uses r12 freon.
94 and up cars use r134 freon that i know of. the compressors might be different. and in that case, u would have to buy a r12 compressor fitted for ur car. r12 is going to be extinct soon so it might be a good idea to retromod and get the a/c shop to convert ur a/c system to run r134a
good idea to get a new drier when u re-do a/c
Re: Will a 95 complete ac system fit a 92? (integraXTC)
i would imagine that it would be VERY expensive. INstalling AC systems are not easy. Plus charging them up and making sure they work correctly. I hate people that dump freon into the ozone layer. best of luck with the replacement though.
Location: Why so you can pretend like youre interested, FL/OK
Re: (integraXTC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraXTC »</TD></TR><TR><TD CLASS="quote">so even if I find the stuff for a 95(I mean the whole system) I can't use it in my 92? </TD></TR></TABLE>
So long as you're replacing everything you can. AC has really been one of the only things I don't have the tools or equipment for. But 99% says you can swap out systems no problem. I don't know any shops that won't use their own or new parts for this though. I think you would be fine if you were pulling and installing everything yourself then going to have the system charged but I don't think it's as easy as just saying that. I'm sure it's much more involved.
yes im pretty positive your system is a r12 freon a/c system...but just use all the civic a/c stuff that is r134a....94/95 civics..put it all in, and goto the shop and tell them it was r12 but now u want it switched to r134a....they will run a vacuum off one of ur lines and convert it...dont know cost
JohnnyEF
06-07-2012 03:16 AM
erikiksaz1
09-24-2004 07:50 PM
