93 ex coupe power window problem
Old 05-23-2005, 01:34 PM
byronl's Avatar
Default 93 ex coupe power window problem
my passenger side window seems to have problems. When I press the switch to go down nothing happens but when I move the switch to up i can some noise coming from the door panel. Is this a symptom of a bad window regulator? because if it is, i'm going to attempt to replace it myself. thx.
Old 05-23-2005, 03:40 PM
nota-ex's Avatar
Default Re: 93 ex coupe power window problem (byronl)
my driverside window has pretty much crapped out on me. At first it would go up slowly, or not at all. Now it stops about 1" from the top and then clicks. I have to get out, pull the window up, then push the button to make it go all the way up.
Mabe check the wiring on your switch and motor. Is it the driverside, passenger-side, or both switches that don't work to make the window go down?
Old 05-23-2005, 04:12 PM
byronl's Avatar
Default Re: 93 ex coupe power window problem (nota-ex)
the driverside window and driverside switch works fine, it's just the passenger side window that has a problem, I press up on the switch I hear a noise from the door, it sounds like it's trying but when I press down, nothing happens.
Old 05-23-2005, 04:59 PM
nota-ex's Avatar
but does the window go down when you push the down button on the passenger or driver side? Or are both not working to make the passenger side go down.
If neither button will get it to go down it might be a loose wire on the motor that makes the window go down.
Old 05-23-2005, 05:11 PM
byronl's Avatar
the driverside window goes down when I press down on the switch.
Old 05-24-2005, 06:21 AM
byronl's Avatar
anybody?
Old 05-24-2005, 08:35 AM
Mr. Indecisive
EJ8VTEC's Avatar
Default Re: (byronl)
might be the reg, or maybe its just off track. There are 2 screews to take off the door panel, check it out
Old 05-25-2005, 06:46 PM
byronl's Avatar
Default Re: (EJ8VTEC)
alright I took off the door panel and took a look at it. Exactly what am I looking for? the window looks like it's on the track.
girliehonda
Honda Civic (2001 - 2005)
10
10-16-2016 03:32 PM
slipstreamvash
02-01-2015 05:26 AM
hondapwr
07-17-2009 05:30 PM
robwilhelm
09-19-2007 10:05 AM
92ehatch
03-03-2006 02:49 AM
Quick Reply: 93 ex coupe power window problem
