Help: Squeeling belt
I searched around but couldn't find anything usefull.
Whenever I start my 92 VX the belt squeels real loud for a couple seconds then stops. It also on occassion (but rarely) will do the same thing at stop lights until I give it a little bit of gas. I checked the tension on the belt it's definetly not too loose so what else could be problem here?
an old belt?
which belt did u check theres more then one
power steering, a/c and alternator.. check all 3 if u have em..
if its a big problem jsut throw some dishsoap on the belt and the squeal will stop
Re: (Lamb)
i have the same problem with mines...i think its either the ALT. is going or it has a bad bearing...still have the problem so i couldnt tell u what it is..but check those 2 things
Re: Help: Squeeling belt (Lamb)
In time the grippy Rubber BELT gets hard and glazed and starts to slip
For a cheap fix, you can pull the belt and rough sand it but it'll start to squeek again within the next 1K miles or so<<< Can't UN HARDEN the belt.
Re: Help: Squeeling belt (HumanResource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource »</TD></TR><TR><TD CLASS="quote">In time the grippy Rubber BELT gets hard and glazed and starts to slip
For a cheap fix, you can pull the belt and rough sand it but it'll start to squeek again within the next 1K miles or so<<< Can't UN HARDEN the belt.</TD></TR></TABLE>
Yeah, or you can just get a new belt...not too much money, but thats if the belt is old. Spray some wd-40 on the bearings and ****....like was stated previously, check all belts y0!
