Please Help. What Ecu should i use in my swap. Harness Problem.
Hey guys. i need some opinions..my car is a 98 Ek Dx, i recently install a ZC pistons in my D16Y7 block. and i put the D16A6 head, with headers, exhaust, CAI, probably i run in 11.3:1 of compression.
well, yesterday , i bought a 93Si gearbox and a ACT combo clutch.
i feel pretty hard when the car goes on 5K rpm to 7K. But i feel that my car need more revvs.. and i installed on it the P2P (Civic EX) , but didnt work it. the revs keep on 4K and dont pass more..
well. i think may be should be a vtec code , well, isnīt a problem.. i can install the solenoid to deceit the ECU and run normal.
The Vtec ecu rev limiter is 7,500rpm. i only gain just 0.500 rpm compared with the orginal ECU.
The question is. Should i use the VTEC Ecu and run with that, because i heard that i will gain more air/gas.. or this change will not work and should i use the stock ecu.??...and the other question is: the Vtec Ecu of a Manual car, has the same air/fuel curve compared in to a Vtec Ecu Automatic Car??
sorry for my english but isnt my native language. Thanks you for any help, it would be great!!...
Modified by JDM-Spec at 11:56 AM 5/23/2005
Re: Please Help. What Ecu should i use in my swap. Harness Problem. (JDM-Spec)
you should try to find a chipped ecu, or hondata. you changed enough internals to require tuning, and there isn't a stock ignition/fuel map out there for this setup, especially with bolt ons too. the timing/ignition maps are the same between manual and auto ecu's.
Re: Please Help. What Ecu should i use in my swap. Harness Problem. (IHateJDM)
i think i didnt have enough internals to look for a hondata...
i only require a P2P chipped, or a P2P stock because the map are more agressive compared with the p2E. .. thank you for the auto/manual map answer .
anyone with the same problem?.. the problem is that i have OBD2 harnesss and isnt easy to find some chipped ecu right here.
The only i ever seen is a Erick Racing. but it was stealed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-Spec »</TD></TR><TR><TD CLASS="quote">i think i didnt have enough internals to look for a hondata...
your bolt on's (intake, header, exhaust) increase the amount of air that can make it to the cylinders, and the pistons upped your compression, all of which alters your air/fuel ratio. You could be safe on a more aggressive map if it adds more fuel than stock. with your setup and stock ecu, it'll be really easy to lean out and cause detonation. you could even get a vafc to add some fuel, but a chipped ecu or hondata is a lot more reliable. Good luck.
i took a OBD2A to OBD1 jumper converter, and im waiting for a Integra OBD1 Chipped Ecu by ErickRacing.com ... .
what do you think guys... im in the correct way?...
D17A2~VTEC
03-11-2006 05:38 PM
