Bench bleeding---air is being sucked back in!
So I'm benching bleeding a master cylinder. I hook up a clear tubing into the cylinder and the other end is in the resorvoir, full of brake fluid.
When I pump in the cylinder, I see the air being pushed out. But when I release the cylinder, the same air that was pushed out, gets sucked right in!
What's going on?
What's going on?
Re: Bench bleeding---air is being sucked back in! (VWkila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila »</TD></TR><TR><TD CLASS="quote">
What's going on? </TD></TR></TABLE>
you might be doing it wrong.
u have to tighten tyhe bleed bolt before u release the pedal
unless u have a 1 way bleed bolt u can pickup for a couple bucks (lets **** out, but not back in)
Re: Bench bleeding---air is being sucked back in! (Morning Call)
Well, the MC is cramped on my vise. And the MC came with a kit that includes clear hose, etc., 'though I guess I can hookup a bleed valve to it.
I think the problem is that my clear hose is too long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila »</TD></TR><TR><TD CLASS="quote">I think the problem is that my clear hose is too long. </TD></TR></TABLE>
Nope... I just tried this, still doesn't work.
Any ideas?
Any ideas?
Fill reservoir with fluid. Run hoses from MC into fluid... then start pumping. You'll eventually be able to push all bubbles out.
If you have serious bubble issues... pump it then hold tube up and allow bubbles to bleed up/out, then put back into fluid in reservoir.
Re: Bench bleeding---air is being sucked back in! (splitime)
what i do to bench bleed while in the vise is put ur fingers over the 2 holes push the rod in but not all the way like 3/4th the way keep ur fingers pressed down a lil bit with squirt out but keep ur fingers on the holes that way now air will go back it do it like 4to 5 times i think should be good then tose it on. i have done 2 that way and no problems
1 Post
I did this very thing this past weekend myself - it will take time, I probably cycled the push rod on my MC 20 times to get all of the air out of it.
Re: Bench bleeding---air is being sucked back in! (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">I did this very thing this past weekend myself - it will take time, I probably cycled the push rod on my MC 20 times to get all of the air out of it.</TD></TR></TABLE>
I've been doing this since last Saturday and it still has air.
Re: Bench bleeding---air is being sucked back in! (93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_hatch »</TD></TR><TR><TD CLASS="quote">what i do to bench bleed while in the vise is put ur fingers over the 2 holes push the rod in but not all the way like 3/4th the way keep ur fingers pressed down a lil bit will squirt out but keep ur fingers on the holes that way no air will go back it do it like 4to 5 times i think should be good then tose it on. i have done 2 that way and no problems</TD></TR></TABLE>
This is how i've been doing it for years.
Re: Bench bleeding---air is being sucked back in! (xoutlawz00x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xoutlawz00x »</TD></TR><TR><TD CLASS="quote">guys im gonna change my mc and bb soon do i need to bench bleed.. what excatly is bench bleeding</TD></TR></TABLE>
Well, bench bleding a MC involves you getting rid of all the air that's trapped in your new MC. One of the most important steps in bleeding your brake system, yet most overlooked.
You put the new MC in a vise, and a new MC will usually come with a bleeding kit, hook it up with tubing and submerge the other end of the tubing in brake fluid and pump.
http://www.geocities.com/aussiebug1970/bleed
Leb_CRX
05-12-2005 06:25 AM
mingchi69
06-23-2003 06:25 PM
