Calling D-series tranny experts!! HELP NEEDED!!!
Ok, here's my little situation.
I've bought a tranny from a guy for my 98 EX. I want to know if there is any physical way of telling the difference between say an EX tranny (S40) i believe, and a dx or cx tranny.
The Identification and VIn numbers are not still on the tranny. He says it is off a 98 EX.
Please don't bitch to me about how the tranny is probably stolen, hot, etc. I really don't care. It was local and allowed me to get some transportation as quickly as possible.
So if you know any way i can check for sure that it is an ex before putting it in the car, please let me know. THanks
Re: Calling D-series tranny experts!! HELP NEEDED!!! (2muchPSI)
pull the internals and count the teeth
search under username mistabone or something to that. he did a full write up to d-series trannies.
also, you know after you put it in the car that you will be able to tell the difference between a ex and cx tranny
Re: Calling D-series tranny experts!! HELP NEEDED!!! (dohcdelsol)
yeah, i know i can tell the difference driving it, but I was just hoping there was a way to tell without tearing the damn thing apart. Thanks anyway
Location: Why so you can pretend like youre interested, FL/OK
No other way without the identification information off the trans. If you decide to put the the trans on here is the site:
http://home.cinci.rr.com/mistab0ne/tranny.html
Re: Calling D-series tranny experts!! HELP NEEDED!!! (INVALID)
#1 For the EX the diff carrier bearing ID is 40mm. You can measure it fairly easily if you pop out the axle seals.
#2 Remove the oil fill plug. Mark one tooth on the ring gear with a permanent marker. Rotate the input shaft and count the teeth on the ring gear. If you have 68 teeth, it should be the 4.25 FD of the EX trans.
#3 There is a circular stamp by the oil filler hole. A000 is the small bearing DX/LX/HX/CX case. B000 is the large bearing EX case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2muchPSI »</TD></TR><TR><TD CLASS="quote">
probably a stolen tranny.
Re: Calling D-series tranny experts!! HELP NEEDED!!! (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">#1 For the EX the diff carrier bearing ID is 40mm. You can measure it fairly easily if you pop out the axle seals.
#3 There is a circular stamp by the oil filler hole. A000 is the small bearing DX/LX/HX/CX case. B000 is the large bearing EX case.</TD></TR></TABLE>
Exaclty true
Beat me to it tho
Exaclty true
Beat me to it tho
turbod16y7vtec
12-12-2002 09:22 AM
