Would you guys recommend a Flex-Pipe as a Str8 Pipe????? INPUT NEEDED!!!!!!
Like the title says, would you guys recommend a Flex-Pipe as a Test pipe????
Someting similar to this......
http://www.kteller.com/store/p...d/210
Re: Would you guys recommend a Flex-Pipe as a Str8 Pipe????? INPUT NEEDED!!!!!! (Bonez21)
I guess you could if you wanted to. If you don't use a tapered flange for you test pipe, you'll need a flex pipe anyways. So you could incorporate the flex pipe into the test pipe.
Re: Would you guys recommend a Flex-Pipe as a Str8 Pipe????? INPUT NEEDED!!!!!! (Ghetto Civic HX)
good advice thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghetto Civic HX »</TD></TR><TR><TD CLASS="quote">I guess you could if you wanted to. If you don't use a tapered flange for you test pipe, you'll need a flex pipe anyways. So you could incorporate the flex pipe into the test pipe.</TD></TR></TABLE>
Re: Would you guys recommend a Flex-Pipe as a Str8 Pipe????? INPUT NEEDED!!!!!! (rw92civic)
thanx that sounds like a good plan
surprised I didn't come up with that one ha lol
Tong.Y
01-02-2011 08:14 AM
