b18c5 2000 civic hatchback - parasitic battery drain
I am having a parasitic battery drain of a 0.23 ma and i cant seem to figure it out i already did the fuse pull and i pull the ignition fuse and it drops to 0.01 and changed out the wiring for that and even then still didnt do anything i need help
I never narc'd on nobody!
re: b18c5 2000 civic hatchback - parasitic battery drain
If pulling the fuse fixed the drain, and replacing the wiring for your ignition didn't solve the problem, then wouldn't logic dictate that the drain is somewhere in your ignition switch? Seems like a pretty logical next step to me.
Ok so unplugged my auto start and the draw dropped to 0.03 and when the car is running it is at 12.36 and when the lights are on its at 11.80 and drops slowly what could that be?
When i drive the battery light comes on then dissappears when i push in the clutch but then after 5 mins of driving the light is gone but then i start it again and it comes on
A parasitic draw of anything less than 30ma should be considered normal on these Hondas. So that's that, its fine.
Now your other post with the operating voltage at/under 12.6v while the engine is running is a simple example of a bad alternator.
I would suggest testing your alternator output(seems like you already did) and replacing it with a good known brand. (Denso)
How old is the battery?
So you have a new battery and alternator, and are still getting a battery light and your running voltage is less than 12.6volts?
Hmmmmm...
Can you post a pic of the connections at the alternator? Who installed it?
Hmmmmm...
2000 honda civic hatchback b18c5
So turned my car on after installing a new belt and alternator and it squeels anyone know how and also if my belt is loose would that cause my alternator to not charge my battery?
rewerbcrx
14
08-16-2007 11:42 PM
1 Cam Wonder
14
11-17-2004 08:21 AM
ITRbroham
11-04-2004 06:30 AM
