master cylinder help
Old 10-14-2015, 02:07 PM
gotenz90640's Avatar
Default master cylinder help
I just recently replaced my master cylinder cause it would sink to the floor periodically when it would get hot it works fine now only problem is now that I put the new master cylinder I checked for leaks and it's leaking on both brakes lines and the right bolt on the master cylinder not alot but moist.i cleaned it with brake clean thinking I didn't clean it when I did the job but check it the next day and it was moist with brake fluid. Any suggestions? The master cylinder is a brand new duralast
Old 10-14-2015, 02:09 PM
Former User's Avatar
Default Re: master cylinder help
Post pics of the leak locations.
Also, car information is always required when you make a tech thread.
Old 10-14-2015, 09:40 PM
Brake lines that connect to master cylinder and right screw that holds master cylinder to booster. I have a 92 civic si
Old 10-14-2015, 10:48 PM
Stancetard Hate Monger
eghatch9295's Avatar
sounds like you may have messed up on the install. pics.
thecruzs2007@yahoo.com
03-20-2010 03:52 PM
93sivtec
12-23-2007 08:17 AM
integra123
08-08-2006 05:52 PM
Tommy_Gunns
12-07-2002 09:49 PM
erniecars
11-18-2002 12:41 PM
Quick Reply: master cylinder help
