'95 Civic EX I can't hammer out my wheel hub
Old Oct 11, 2015 | 02:18 PM
Zeronamous's Avatar
Icon5 '95 Civic EX I can't hammer out my wheel hub
This is what I'm working with:
So I put the axle socket over the wheel hub and hammer, but it doesn't move at all.
I know there's a clip in there, but it holds the bearing in, not the hub, right? So I should be find hammering out the hub first, then taking the clip out, then using my press kit for getting the bearing out. It just will not move at all though.
Does this mean I need to throw $200 at a press now? Because the cost of this is just skyrocketing right now. I need a new ball joint, new CV axle after the last one broke, a new wheel (I had to saw through it with an angle grinder), and all these tools...
Old Oct 11, 2015 | 02:20 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: '95 Civic EX I can't hammer out my wheel hub
Or you could take it to a machine shop, and pay them to press it for you. Ya know, do the job the right way once.
Old Oct 11, 2015 | 02:32 PM
Zeronamous's Avatar
How much do you think they'd charge for something like that?
Old Oct 11, 2015 | 02:33 PM
tony_2018's Avatar
Fish Twig
20 to 100 depending on who does the work.
Old Oct 11, 2015 | 02:39 PM
NotARaCist's Avatar
Bring them the replacement bearing, it's a quick and easy press out/press in, shouldn't be more than $60.
Old Oct 11, 2015 | 02:44 PM
Zeronamous's Avatar
Sounds reasonable... I watched this video from Chrisfix on doing wheel bearings and hubs, and only after I got this far did I notice there was a cut where it looks really easy for him to hammer out the wheel hub:
Skip to 5:20 to see what I'm talking about
Hell, maybe I should just do the other side while I'm at it. CV Axle, lower ball joint, etc.
I'm doing it this way because I'm low on money, quit my job, and need this working quickly.
Old Oct 11, 2015 | 02:57 PM
tony_2018's Avatar
Fish Twig
If the wheel bearing was never replaced before by you during the time you had it than you can be damn sure its going to be a rocky road, like offroad climbing a 80 degree with only a 2wd.
Old Oct 11, 2015 | 03:24 PM
Zeronamous's Avatar
I see what you mean. I doubt it was knowing the last guy. Anything that took that much effort was never done (so neglected basically), and anything that took no effort was done poorly.
I think I'll just get the press, cause I'll be doing this with the other side and I'm sure my dad could use it or something once I'm done with it. If not, just resell it on Ebay or something, right?
Besides my Go to Hell fund is good enough for this stuff. I just don't like digging into it too much.
Old Oct 11, 2015 | 03:27 PM
NotARaCist's Avatar
Harbor Freight has some cheap hand presses, if you want to buy your own.
Old Oct 12, 2015 | 08:50 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I still think it's easier to pay the machine shop for some of these jobs. Not only is it the press but it's all the precise sized receiver cups and press adapters etc.
Just like for the ball joints, just the c-clamp basic ball joint set won't work, you then need the Honda adapters etc.
Here you will also need to figure out or find a proper cradle to hold the knuckle once you have the proper sized press adapter.
Honestly, unless you are going to make a living of pressing out wheel bearings and bushings, I don't feel the investment into all the tools and adapters as being fruitful. You shouldn't come anywhere near the cost to have the job done a few times at a machine shop as it will for all the hardware to DIY.
Just my opinion which doesn't apply to desire or want. If you want to get your own stuff, go for it, please just be aware, the press alone likely isn't everything you need for the job.
Cheers.
Old Oct 12, 2015 | 10:08 AM
tony_2018's Avatar
Fish Twig
It definitely is, but if you think you're going to put more use into the hydraulic press than get one.
Old Oct 12, 2015 | 07:40 PM
eghatch9295's Avatar
Stancetard Hate Monger
i freeze/beat ball joints in. zero torn boots, zero presses. success!
crv-techu
Sep 1, 2008 09:19 PM
spets
Suspension & Brakes
Apr 5, 2008 05:31 PM
jBj
Apr 17, 2007 12:54 PM
lowered94accord
Mar 16, 2007 10:24 PM
tilt
Mar 2, 2003 06:08 PM
