EG CX - rpms increase and decrease repeatedly
Old Oct 5, 2015 | 08:32 PM
XSwordFishX's Avatar
Default EG CX - rpms increase and decrease repeatedly
When I push my car and slow to an idle my rmps tend to increase and decrease repeatedly by themselves ranging from 1000 to 2000 rmps. When I drive it runs perfectly fine. Could anyone tell me why ?
Old Oct 5, 2015 | 09:14 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default re: EG CX - rpms increase and decrease repeatedly
Can you be a little more specific on what you are doing when the idle rises? I am not sure what you mean by push your car.
And slow to an idle, is it surging just as you press the brake or does it surge also when you are just holding the brake at a full stop?
Using the brake causes a vacuum change and the car raises idle to bring the vacuum back up. Pumping your brakes will raise the idle a fair amount.
Not sure if this is the behavior which you are experiencing.
Old Oct 5, 2015 | 09:38 PM
NotARaCist's Avatar
I never narc'd on nobody!
Why is following the rules so hard for people?
https://honda-tech.com/honda-civic-d...sting-3002401/
Follow the rules - Fill us in on the missing information. In the mean time, properly bleed your coolant. Park the car on an up-hill slant, remove the radiator cap, and let the car run for two cooling fan cycles, keeping the radiator topped off at all times. Should take about 10 minutes.
Old Oct 6, 2015 | 06:08 AM
rice a roni's Avatar
Sounds like surging. FITV under the throttle body.
Old Oct 6, 2015 | 02:08 PM
Thats the exacttttt thing Im dealing with if I push about 60 then come to a stop my rmps just go up and down with my foot on the brake ,some times the clutch too if Im lazy, then when I take it off it either starts up again (going up and down that is) or stops. I asked a guy at the parts shop I normally go to and he said a vacuum problem or something clogged I couldnt remember
Old Oct 6, 2015 | 02:14 PM
Its a 93 Honda Civic Eg CX stock engine no check engine light um I did have a valve gasket leak but fixed it, the person who own my car before me tore the damn thing up. I did have a bit of a splash of water sucked into my engine a few months back, right into my exhaust system but it survived surprisingly. Thats about all it think that might be a contributor
Old Oct 7, 2015 | 12:00 AM
NotARaCist's Avatar
Bleed. Your. Coolant.
We can work from there, but that's the place you want to start.
Old Oct 7, 2015 | 02:48 PM
tamboo's Avatar
10 Year Member
Old Oct 7, 2015 | 06:15 PM
Former User's Avatar
Default Re: EG CX - rpms increase and decrease repeatedly
Also clean the IACV and post the CEL codes.
Old Oct 7, 2015 | 06:56 PM
tony_2018's Avatar
Fish Twig
I believe what the OP is saying is he dogs out his car and slows down to a stop, idle speed, and that is when his rpm's are "hunting", start to fluctuate.
Any thing changed, replaced, lately?
Old Oct 7, 2015 | 09:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Hey Swordfish, you still have been very vague.
I asked if your rpm change was either one thing or the other and you replied with "yeah that's it" but not which it was.
Another words, I asked if you wanted soup or salad and you said, that would be nice.
We still can't be sure of anything at this point.
I'm not trying to sound rude so let me try a different approach.
1) Does your rpm repeatedly go up and down when you are at a full stop and the brake is depressed? (yes/no)
1) Does your rpm repeatedly change when you run the car in neutral with the parking brake engaged and no pedals depressed? (yes/no)
If you can provide a yes or no to both of those questions, some definitive understanding can happen and we can progress instead of taking pot shots in the dark.
The reason I'm not sure it's idle surge is if you pump your brake pedal the idle will continually rise.
Now if you are saying your rpm goes up and down multiple times with only a single press of the brake pedal.... That is a problem.
Old Oct 10, 2015 | 12:54 PM
Sorry about that let me clarify by saying that it does it when I come to a complete stop (no peddles depressed) not when Im pumping the break. It also doesn't do it every time I drive my car. I drive my car daily so I really cant figure out what the cause is. Sometimes when I start to drive again after my stop and then stop again the rpms might stay leveled its really strange. Blah please give me some good news !
Old Oct 10, 2015 | 01:33 PM
Originally Posted by RonJ
Also clean the IACV
OP --> Rather than post, act^.
Does the CEL work?
Old Oct 10, 2015 | 01:40 PM
NotARaCist's Avatar
How many times do we need to tell you to bleed your coolant before you actually do it?
For the record, this is #4. #5, if you count RonJ's quote.
Old Oct 10, 2015 | 01:42 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Thanks for clarifying.
RonJ above me has quoted all the relevant advise for your situation.
If you have questions about any of the 3 procedures he quoted, please don't hesitate to ask.
Also RonJ's question about the CEL is an important question too.
Old Oct 10, 2015 | 01:49 PM
Sorry ya'll Im a stubborn lady, I just wanted to make sure everyone here came to the same conclusion before I started working!!!!
Old Oct 10, 2015 | 01:53 PM
And to be honest Im not to sure about my check engine light... is there anyway to see if it works at all ?
Old Oct 10, 2015 | 01:58 PM
Consensus is not necessary - all are possibilities.
Turn key from off to ON(II). Does CEL turn on for 2 seconds and then turn off?
Old Oct 10, 2015 | 02:00 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
When you first turn the car to the on position (II) the CEL yellow/orange engine light should come on for about 2 seconds as the fuel pump primes, then turn off.
If you don't see the little yellow engine illuminate, then your bulb is quite likely burned out.
Old Oct 10, 2015 | 02:02 PM
Or removed by previous owner.
OH....yea it does work...I feel stupid.... -_- lonnggg day at work excuse me
Old Oct 10, 2015 | 02:03 PM
I was thinking about whether or not the reading was accurate or not, like actually working working
hahahah i feel like an idiot
Old Oct 10, 2015 | 06:48 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Don't sweat it, just proves you're a fellow human being.
Since the CEL works and isn't always on... Just work the three things quoted by RonJ above and report back your findings afterwords. Or ask any questions you have before or during any of the processes.
Good luck and most of all, if at all possible have fun.
Old Oct 10, 2015 | 10:48 PM
NotARaCist's Avatar
Please don't triple post. Use edit button.
Last edited by TomCat39; Oct 11, 2015 at 08:08 AM. Reason: Edited instead of deleting intolerance.
lude98SH
Jan 24, 2006 03:39 PM
EGkid
Jun 1, 2005 12:03 PM
Dan2
Jan 2, 2005 08:22 PM
iwannaboostmyteg
Feb 7, 2004 10:43 AM
