1998 Civic Ex HOW TO CHANGE HEAD GASKET???
Old 10-05-2015, 01:03 PM
Tenn_89's Avatar
Icon5 1998 Civic Ex HOW TO CHANGE HEAD GASKET???
Needing a head gasket change on my car, (1998 civic ex 230k miles) needing some help on how to, A walk-through would be nice. What's the difficulty? 1-10? Need it done ASAP. Thanks!
Tenn_89 is offline
Old 10-05-2015, 01:13 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: 1998 Civic Ex HOW TO CHANGE HEAD GASKET???
We expect people to put in a modicum of effort around here. It's pretty clear you haven't, but you're new, so I'll be nice.
First off, start by reading this. The rules are not optional.
https://honda-tech.com/honda-civic-d...sting-3002401/
Then, read this. The FAQ sticky will answer your question 9 times out of 10, and does in fact contain the answer to your question.
https://honda-tech.com/honda-civic-d...tions-1998336/
Once you've gone through those, you'll find your answer in this thread.
https://honda-tech.com/honda-civic-d...be-not-735196/
I would also highly recommend buying (or downloading, we won't judge) the FSM for your car. It's the book the techs use to do work like this. It will have the most detailed write-up for you.
NotARaCist is offline
Old 10-05-2015, 02:22 PM
Tenn_89's Avatar
I was obviously pretty clear of what I am in need of, your post was about a swap, but I thank you for the help. Just need to know what I need to do to change the head gasket on my D16y8 engine is all. Can upload pics etc... Just let me know
Tenn_89 is offline
Old 10-05-2015, 02:43 PM
NotARaCist's Avatar
Gotcha, so you're an idiot. OK, nice is done.
Use your ******* brain, for two ******* seconds. Click the links I spoon-fed you, and put in just a modicum of thought. When you replace a head gasket, what's major step 1?
Removing the head.
When you do a mini-me, what's the major step 1?
Removing the head.
There is absolutely nothing stopping you from following the exact mini-me swap guide I spoon fed you to accomplish your goals. Not a single ******* thing stopping you. Pull your head out of your own ***, and use your ******* brain.
I also gave you a second option - downloading the FSM for your car. Is Google broken for you? Are you incapable of searching for it? Or are you just too ******* lazy to? We aren't here to spoon feed information to you. What you need is readily available, and easily found. Unfuck yourself.
Old 10-05-2015, 03:08 PM
PHANTOM MENACE
24TEN's Avatar
I like that you were nice at first for a change NARC But seriously OP the procedure for removal is the same whether you're converting or not. Follow the link provided and installation is reverse (it's really straight forward). The only thing worth noting is to pay attention to the order of the head bolt removal/install. Not sure if that's covered in the link but it's covered in the FSM.
PS
FSM is something you definitely want.
24TEN is offline
Old 10-05-2015, 04:14 PM
NotARaCist's Avatar
I always try to be nice to brand new members. 9 times out of 10, they turn out to be entitled, ignorant *********, but I still give all new members a shot.
Old 10-05-2015, 08:30 PM
Tenn_89's Avatar
Far from ignorant my friend, just need direct details is all, I have never worked on Honda usually I work on Chevys..but another thing you did not state from what I was told by a Honda dealer technician is, they said I needed to take off crankshaft pully bolt to do a complete head gasket Change ? Is this correct or no ?
Tenn_89 is offline
Old 10-05-2015, 08:36 PM
Tenn_89's Avatar
Oh and Since your the expert, TELL me what needs to be done and be done with it..don't need all the extra drama and bs to make yourself look cool on the forums! Just be real.. You can disrespect me online and talk to me like a piece of ****, when I'm just askin for help, but I guarentee you, you would not do that in person! Now talk to me like a real man with some damn manners! You understand me BOY!?!! If not get off my post
Tenn_89 is offline
Old 10-05-2015, 08:47 PM
Stancetard Hate Monger
eghatch9295's Avatar
nobody is going to write you a write up when several already exist. ill do it for you, paypal me 50 bucks
eghatch9295 is offline
Old 10-05-2015, 08:52 PM
Tenn_89's Avatar
Sure thing ! Money sent ! You probably never changed a head gasket in your life lmao
Tenn_89 is offline
Old 10-05-2015, 09:15 PM
you, sir, are retarded. i have rebuilt dozens of d series engines, and done i have no idea how many head gaskets. at this point, they take me about an hour. since you're a mechanical genius, and a chevy guy, you should be MORE than capable of tearing down this measly little honda. wait- im more annoyed with you than i originally thought. **** your shitty attitude, **** your lazy can't google face, **** your inability to browse the FAQ section, which contains a write up that not only spells out what you need to do, but panders to your low iq by providing pictures, and most of all- **** you.
Old 10-05-2015, 09:24 PM
Tenn_89's Avatar
Haha an hour to rebuild I doubt that! And no thanks you can't **** me I'm a man! You F.A.G
Tenn_89 is offline
Old 10-05-2015, 09:25 PM
Hysterically Calm
TomCat39's Avatar
This sir has ended your thread.
Google 98-00 FSM Ab0ve
and you just might find a good link to the Helm's factory service manual or better yet, support Helms Inc buy buying the manual for about 40 buck from helmsinc.com
It will be your bible and will step you step by step through a head gasket or just about anything else you might want.
Thread Closed
TomCat39 is offline
Edwin Colon
10-02-2015 11:23 PM
Civic082382
10-04-2010 06:22 PM
apr233
03-31-2007 09:14 AM
Quick Reply: 1998 Civic Ex HOW TO CHANGE HEAD GASKET???
