Low idle even on cold start
Hey Honda-tech!
I have this issue for a long time already. On cold start, idle is around 500-600rpm only which should be around 1.5k on cold start. Then on a short drive idle turns to 1.5k rpm on idle. What I do is shut off the engine and restart. Then idle goes back to 500-600rpm only.
What we did already is pull down IACV and Throttle Body then clean but nothing changed.
Note: Had an issue already before on the throttle body coolant passages. (coolant leak specifically) but we had it repaired already.
Thinking of getting a new tbody already.
Car is on Stock P2T ECU. Can anyone help?
Car is 1999 Honda Civic SiR EK4 (B16A2) sedan from the Philippines
Thanks
Thanks
I never narc'd on nobody!
Re: Low idle even on cold start
https://honda-tech.com/honda-civic-d...sting-3002401/
We shouldn't have to make assumptions or guesses. Basic information (ya know, like what car you have) is required for a reason.
