95 civic sputters and stalls HELP
So heres the situation, my cars been running A-okay besides the fact that the mothafucka keeps failing smog. Now i got some more issues, it's a first for me. So my car has been stalling quite a few times and it will happen frequently. It's stalled while reversing, stalled while idling, even stalls when coming to a stop at intersections or stop signs. however it turns back on immediately after stalling. Also when coming to a complete stop, as im trying to accelerate after stopping my car sputters and feels very rocky, extreme loss of power.
Now I've done some research and thought it could be a few possible things so IMA go ahead and list all that I've done.
- I've cleaned out the Iac valve
-cleaned out the throttle body
-changed spark plugs, plug wires, and O2 sensor
-replaced cat converter ( also needed this to pass smog, double whammy)
With the work I've done, the car runs better, yet still sputters and stalls. Recently purchased a fuel filter and gonna change mine tomorrow morning. Any other ideas of what it could be ?! I've heard it could be the coil, so it's prob gonna be my next replacement. All answers welcome please help a brotha in need out my fellow car enthusiasts.
Re: 95 civic sputters and stalls HELP
Test ICM an Igniter: http://easyautodiagnostics.com/honda...system-tests-4
Read through all pages 1-5.: http://easyautodiagnostics.com/honda...system-tests-1
Here's some other test can do or should have done instead just blindly (and costly) throwing parts at it:
O2 Sensor: http://troubleshootmyvehicle.com/hon...ygen-sensors-1
Fuel Pressure: http://troubleshootmyvehicle.com/hon...l-pump-tests-1
The car seems to run very rough or sputter only when pressing the gas kinda hard. If I ease into it a couple times its more smooth. However stalling is still occurring!
I never narc'd on nobody!
You're skirting around what RonJ is asking, without giving a definitive answer.
When you turn the key to ON(II), does the CEL come on for ~2 seconds, and then turn back off? Your answer doesn't need to be more than one word - no skirting.
Yeah comes up then goes . I shoulda been more clear
You've failed smog, CEL works with the 2 seconds on then goes off but no codes thrown, sputters and stalls, did 1/2 of the tune up (still missing the new distributor rotor and cap).
Have you done a compression test yet? Also a leak down test could prove very informative.
I believe you are still in the diagnostic stage and need to do a few more tests before you can decide on a direction.
Doing the other half of the tune up is still a good thing to do anyways, regardless.
Best of luck.
Best of luck.
Best of luck.
Best of luck.
could be bad engine coolant temp sensor or main relay, both notorious no start when warm issues.
Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder
Starting Problems
How to Tell if You Have a Faulty Coolant Temperature Sensor - CarsDirect
Starting Problems
Starting Problems
Starting Problems
the deal with the ect sensor is it stops thinking the car is warmed up so ecu continues to dump too much fuel resulting in no start (or something like that).
I think engines normally run start and run fine when the fuel mix is too rich. A bad ECT sensor that causes a too lean issue is the more common cause of a no start problem.
One of my cars (not a Honda) had the similar problem for months (rough idle, misfire and sometime stall when acceleration) after the car was warmed up. I thought at first it was bad cable or bad coil + humidity. But the problem is still there when the weather was dry and sunny. I didn't want to invest too much on this wreck so I just I poured different type of fuel system cleaner in the tank and bought a MAF cleaner and cleaned the Mass air flow sensor and now the problem is gone. I'm not sure which one (fuel cleaner or maf cleaner) solved the problem because I did the "cleaning" at the same time.
*If you want to clean the MAF sensor, make sure you use MAF cleaner nothing else. The sensor is very sensitive and fragile.
hope it helps.
hope it helps.
hope it helps.
hope it helps.
Oups. My bad, I just learned most civic has MAP sensor instead of MAF sensor. I'm not familiar with MAP, but many folks here know how to diagnose this sensor.
This sensor is bloody cheap compare to a MAF sensor. ebay sells a MAP sensor for only 10$. So if I were you, I'd replace this sensor to see if it helps.
edit: As for the fuel system cleaner, I just poured fuel cleaners left in my tool locker ( seaform and Gumout) in my wreck's gas tank..
While we appreciate that you're trying to help, SteveT, please don't unless you know what you're talking about.
92-00 Civics don't use MAF sensors. "Cleaning the MAF" won't accomplish anything, because there isn't one to clean. On top of that, there is no logical reason to compare solutions between two completely unrelated cars. Replacing random parts is stupid. Follow proper diagnostic procedures, and solve the problem correctly. If all you're going to do is slap random parts at it, then please don't waste our time spent trying to help.
https://honda-tech.com/honda-civic-d...sting-3002401/
OP, you were asked, multiple times now, to post your smog sheet. Post it. Straight from the rules -
Members Seeking Technical Help - Read this important message
...Your job is to politely answer all questions directed to you. If you are unable to comply, then don't create a thread and move on. Failure to follow this rule may result in thread closure.
@NotARaCist
I agree with you that we shouldn't replace random part to fix a problem. But It's very frequent that many "mysterious car problems" occur without CEL. If I can't find the cause of the problem, I don't see anything wrong to replace cheapest parts in my car that likely cause the problem.
In many situations, it's much cheaper and faster to fix a car problem by changing suspected parts than "diagnostic", especially when the problems occur randomly.
Let's be practical. If my car was misfiring, has rough idle, sometime stall while accelerating and no CEL, I would replace the rotor, the distributor cap, the cables, all spark plug and the coil, especially when those parts are old. If these new parts fixe all these problems, I'm no going to waste my time to find out which of these parts was culprit. And Yeah, these parts are cheap.
