96' del Sol SI: Engine surge off load (Scan tool data, pics, video)
1996 Honda del Sol SI
D16Y8 OBDII
First things first: CEL, code P0505 (P0505 IAC (Idle Air Control) System Malfunction)
Background
The code was thrown when i was revving my engine around 5k. (showing off admittedly ) After the code, i couldn't idle steadily. If i held the throttle open little bit my idle would surge very rapidly. Cleared the code and car drives normally again. Flash forward a week or so and the CEL comes on again, this time at a stop light. Cleared the code and it drove normally once again. Hasn't had a CEL since.
The reason I made this thread was to address an issue im having currently. After I rev my engine and the needle is dropping back to idle, the engine surges 200-300 rpm. Sometimes it surges once, sometimes twice. Usually happens after i come to a stop at a light or a stop sign.
I have BlueDriver, so i can offer basic scan tool functions. I recorded the surging as well. Sorry for MASSIVE photos, not too savvy with changing the size.
Engine warmed up, pressing the accelerator
Took a regular drive for some datas
Spirited driving
Any help is greatly appreciated.
D16Y8 OBDII
Background
Spirited driving
Re: 96' del Sol SI: Engine surge off load (Scan tool data, pics, video)
I cleaned my IACV recently. Used carb cleaner and sprayed it in both holes of the IACV. Let it air dry for 10 minutes or so and re-installed. Also, just bled my coolant. One thing I noticed with my coolant was small bubbles would appear in the radiator fill neck. And the coolant smelled foul. Its my understanding its supposed to smell sweet?
Thanks
Thanks
I never narc'd on nobody!
Old (like, really ******* old) coolant smells sweet. Animals would drink it, so they added a bittering agent. Burning coolant has a bit of a sweet smell to it, but coolant just sitting there shouldn't. Small bubbles in your coolant points towards the possibility of a damaged head gasket. Buy/borrow/rent a block tester, and use it.
When you bled your coolant, exactly how did you do it?
Ah. Thanks for clarifying.
When i bled my coolant, I opened the radiator when the engine was cold, turned the climate control to heat, turned the fan off, and started the engine. I waited for the fan to turn on and added coolant/water as it sucked it in. Repeated this about 4 times every time the fan turned on. Topped off the coolant overflow and replaced the radiator cap.
Well, you're close, but not quite there. Do it again, but this time, park your car up an incline. Either secure the front on jack stands, or park up a small hill, or use rolling ramps. You need to elevate the front end of your car, so that the radiator fill neck is the highest point in the system.
Do a simple diagnostic test. Remove air intake system and use your finger to cover hole inside throttle body leading to IACV. Does the surging stop or continue?
Best incline i can create with what i'm given.
Hopefully its higher than the coolant lines in the IACV. Maybe i'm never getting it high enough so air is trapped in the IACV coolant line?
The bubbles i was talking about.
I doubt that incline was enough. I'll try again tomorrow when I have my jack.
The plot thickens RonJ. Upon removing the intake tubing, i hear a hissing i've never heard before, but knew instantly what it was. The IACV was open when i turned on my car. When i put my finger over the hole, the engine slows down and runs at about a few hundred rpms it seems. It stays running, but I didn't try to stall it.
The engine only surges after I rev the engine. After it returns to idle it goes up about 300 rpms. It does this once or maybe twice and occurs most often when I stop at a light or stop sign. And it happens every time I stop, especially so on a cold engine.
Ah, I get what you're saying.
The slight incline you got there should be good enough for the bleed, well done. It sounds like you're catching the very first signs of intermittent IACV failure. Diagnosing intermittent is hard enough, but when it's first signs, that just makes it harder.
Properly setting your base idle, and making sure your ignition timing is within spec, couldn't hurt though, and might help stave off the symptoms. Unless someone beats me to it, I'll try to find the Del Sol specific FSM procedure for ya when I get home from work. Did those small bubbles continue with the elevated coolant bleed? If they did, you should still do a block test, just for sanity's sake.
You have an idle surge problem. You learn nothing from a diagnostic test done when the engine is not surging.
That's the catch though, RonJ. His car isn't doing it permanently, just a few times and then catching itself again. We're trying to diagnose a problem that is not only intermittent, but also only showing first signs.
He needs to be prepared to do the test quickly when the problem pops up.
I tried covering the IACV hole during, and after revving the engine. Same behavior as i stated. No matter when I cover the hole, it still just wants to die, unless I open the throttle enough for it to breathe. And in regards to the bubbles, yes they were still present when elevated. When you say block tester, does that mean leak down test? Are they the same?
No. A block tester uses litmus (sometimes paper, sometimes liquid), and basically a mechanic's turkey baster. You put coolant on the litmus, and if it turns colors, you have exhaust gasses in your coolant, which means a damaged head gasket. It's the most definitive diagnostic test, and it's cheap. You should do it, because of those air bubbles in your coolant. Those air bubbles might just be a combination of air in the system plus cavitation, or they might be the early warning signs of a head gasket on the brink of failure. Better to know for sure, than to wait until it fails.
Edit: holy **** I sat on this thread for a while before responding. That's what happens when you post from work, I guess
