What should I do about my clutch
sup guys I recently bought a new eg civic and the clutch is starting to go. Its a dx non-vtec motor and the clutch will be going within the next 6months or so. If you were in my position what would you do, I am also planning on doing a b18 swap by then too hopefully, should i just wait until it goes and put the motor in or what. Oh and the clutch isn't slipping at all but the release is really long. thanks for your help ~Jason~
Re: (preacherboy)
I have the same car...and it's an EJ2 unless it's Japanese. I'm still running the stock clutch w/ 140,000mi and yeah, it's a long release, but I thought that's just the way it is.
Solbros Owns Me
Re: (JRI94)
haha....you can't predict when you're clutch is going to go because of the release point.
Probably just need to bleed it all out good and adjust the pedal from under the dash.
If it's not slipping, or chattering or going nuts, you'll be fine.
Solbros Owns Me
Re: (95civicracer)
somehow flip yourself upside down first....lol
follow the clutch pedal up toward's where it attaches to the slave cylinder. You will see a 14mm nut with an adjustment bolt. Loosen the nut, and adjust the bolt (tighten or loosen) to get the proper amount of slack in the pedal before there is pressure.
Too tight and the clutch will not fully disengage.
Too loose and the clutch will not fully engage.
I usually adjust mine without 1/4 inch of pedal slop
Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">haha....you can't predict when you're clutch is going to go because of the release point.
If it's not slipping, or chattering or going nuts, you'll be fine.</TD></TR></TABLE>
LOL, exactly. If you're clutch was going out, your car would lag after you released the clutch pedal and accelerated.....
phokingthai
Transmission & Drivetrain
07-04-2014 01:53 PM
