SRS Light wont go away
i put a momo steering wheel on the srs light is on. I know its b/c i took out the airbag but how can i get it off with out taking the light out of the cluster?
I search and i found a way to fix it if its been pluged back up. Can anyone help?
Re: SRS Light wont go away (GreenEX)
It's going to stay on if you don't have an airbag in the car. Just pull the plug out of the back of the cluster (but your passenger airbag won't work either).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenEX »</TD></TR><TR><TD CLASS="quote">i just dont want to pull that plug or the light want a way to fix it </TD></TR></TABLE>
Put your stock steering wheel back on and reset it according to the instructions here on this site.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenEX »</TD></TR><TR><TD CLASS="quote">i like the steering wheel though so there is no way ?</TD></TR></TABLE>
Not unless you want to do what I suggested to begin with. That SRS light is telling you that the OEM SRS equipment is missing. Unless you replace it there is no way to turn it off without pulling the plug/light (which I don't know how to do honestly).
Re: SRS Light wont go away (Ricey McRicerton)
i'm having same problems... after put momo on mine, even though i took out the SRS fuse under the dash board, the light still on.. i think i'm gonna just take out the light bulb behind cluster, but i'm sure there is other way..
BUMP for same situation!!!
Re: (jcarothers)
taking the bulb out is the easiest way of doing it
there's a device on the market that plugs into your original SRS plug and 'cheats' your car saying there's an airbag installed.. therefore turning off the light.. but i dont know where to get them.. i saw it on some tv show they use it to scam people when buying rebuilt used cars without putting a new airbag in..
hope it helps
hope it helps
Re: (JDM-FREAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-FREAK »</TD></TR><TR><TD CLASS="quote">what do you mean as all equipment??...
Means everything thats associated with the srs sytems ie, all wires. srs brain... Best way to solve the problem is to remove the light
1 Post
Re: (Slammed Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed Si »</TD></TR><TR><TD CLASS="quote">
Means everything thats associated with the srs sytems ie, all wires. srs brain... Best way to solve the problem is to remove the light</TD></TR></TABLE>
bingo!
but yea, the best thing to do would be remove the light.. it only takes like 10min. 2min, if you know exactly what you're doing.
bingo!
1 Post
Re: (Hybrid Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Racer »</TD></TR><TR><TD CLASS="quote">
i like to have my face cushioned, instead of metal and leather slamming into it... </TD></TR></TABLE>
you say that like if you don't have an airbag, the steering wheel is going to jump out and whoop your ***. I think if I got in an accident with my car my face would miss the steering wheel anyway.
Banned
Yes...use a electric tape to cover up your SRS light on your cluster.
Vice President/CEO
Re: SRS Light wont go away (EM1b18cR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1b18cR »</TD></TR><TR><TD CLASS="quote">
Yes...use a electric tape to cover up your SRS light on your cluster. </TD></TR></TABLE>
haha!! thats what i did! You cant even see the black tape either...
Re: (WrongWD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">put in a jumper between the last pin on the right side, and the 4th pin from the left, your SRS light will go away.</TD></TR></TABLE>
can u get a pic of what u are talking about and maybe more info
