Differences in Si TB and GSR TB
Can those be interchanged?
The reason im asking is that my friend has Si TB portted to 64mm and i wanna use it with my Skunk2 IM, just wanna make sure if we exchange, everything will bolt up?
I checked Honda and they use the same gasket, so im guessing same thing?
thanx guys!
thanx guys!
Re: Differences in Si TB and GSR TB (TrboInteg)
does anyone know for <U>sure</U>??
Im also interested in getting a new tb, its good to know if its an easy swap.
thanks
thanks
Re: (Denis Si)
so whats the verdict here?
essentially the b18c and b16 throttle bodies should be interchangeable. The coolant lines and such are they the same?
thanks
thanks
Re: (CIVIC dude)
yes they are interchangeable.
the only diffference between the gsr and SI tb is that the gsr pulley is upside down since on a stock gsr, it needs to be since the throttle cable is mounted right above the tb. but since you already have a gsr tb on your skunk2, i imagine that you alreayd have had that fixed.
TheGSRGuy
04-03-2006 11:41 AM
