Need help Removing ABS - 94 Civic SI
I made a post a couple weeks ago, but it is already archived.. I finally got off my *** and pulled my motor out. So all my abs/brake stuff is easily accessable. Basically I need to know what exactly what I need to remove my ABS unit. I know I will need the brake lines inside the engine bay. I am guessing I will need a new distribution block as well? Also will I need a new MC? Or will my stock one work? I'd like to get some info asap so I can try to locate these parts soon and switch them up. Thanks a lot for any help I can get..
I searched but could only find help with integras..
Re: Need help Removing ABS - 94 Civic SI (CharmCity)
Okay I took a couple pictures figuring they may help aid in my search. Yes I did some off roading(wanna be rally driver ) and yes they engine bay is going to be fully cleaned very soon.. anyway the first picture is of all the brake lines that go into the ABS unit, the second is the distribution block.. I al pretty sure I will need a nother one of those, and am guessing I'll just need all the brake lines in the engine bay.
oy, that stuff is all different. you're going to need like every brake line in the engine bay and a new distribution block.
big job
big job
Re: Need help Removing ABS - 94 Civic SI (zelifcam)
Yeah, that's all I need to know.. I just would like to hear from someone who has actually done it so I get the correct info.. If I do just need all the brake lines in the engine bay and the distribution block then it's all good.. not hard stuff to redo.. also do I need to get the Non-ABS MC?
anyone else have any ideas? probably gonna make a trip to a junkyard this weekend but I don't really want to buy the wrong stuff..
