2000 Civic Starts hard when fuel is low.
My 2000 honda civic that I bought new has always started hard after sitting when the fuel is low (<1/8 tank). Anyone else have this problem? Mine has done this since the day I bought it.
Also, the front suspension makes a lot of noise when hitting bumps around corners when it is cold out. Anyone else have that?
Thanks!
Thanks!
1 Post
Re: 2000 Civic Starts hard when fuel is low. (joshs_232)
My **** does that when its cold out too but thats in my daily driver...as far as your car starting hard goes, im not really sure what that means????
Re: 2000 Civic Starts hard when fuel is low. (B18C-Rsi)
If you mean you have to turn the key and hold it when you have low gas, that happens with every car.
The suspension the I'd check you alignment
All are fairly normal
Re: 2000 Civic Starts hard when fuel is low. (Mrfirefox)
well make sure that you let the car prime and the engine light turns off cause it takes longer for it to prime when you have less fuel in the car so just leave the car in the on position for a few seconds and then start it
Re: 2000 Civic Starts hard when fuel is low. (Soccerking3000)
As stated, it is normal. Just leave the key in the ON position for 5-10 seconds before you crank the car. As far as the suspension stuff, I'd get it looked at, but it's probally just the way it is.
jackel0808
13
06-15-2014 03:40 PM
