confused about what gen. my b16 is?????
alright i know that the year is stamped under the heat shield and its the closest circle to they distributor side correct??? and it is stamped 5601813 so is that a 2nd gen.???? also it is stamped upside down i think and if it is then it says 9/8 so is that correct???
Re: confused about what gen. my b16 is????? (h0tsihatch)
is it a b16a or a b16a2? did t come mated with a cable tranny (not always the correct way of determining though), ummm... is it a stock valve cover? if so then check to see if the "VTEC" is smaller than the "DOHC" then its a first gen, but if its backwards then its a later gen. These are all very nono-concrete ways of determining it though. there are others, like something to do with wires going to the distributer or something, but I forgot. Try http://www.hybridgarage.com/
Re: confused about what gen. my b16 is????? (EGCoupe)
actually this is the link you're looking for.
http://www.hybridgarage.com/tech/b16/index.html
what OBD is it?
thats all that really matters.
EDIT: if you're going to add info, edit your post like this. don't post *****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGCoupe »</TD></TR><TR><TD CLASS="quote">actually this is the link you're looking for.
http://www.hybridgarage.com/tech/b16/index.html</TD></TR></TABLE>
Re: confused about what gen. my b16 is????? (JUN EK9)
my friend tells me that it is an obd1 and now i think my motor is jdm and since it is obd1 it should be a 1st. gen. but im still not too sure but is there any way i can tell from my tranny???
Solbros Owns Me
OBD1 B16 is 2nd gen SirII
it'll say B16A...won't say A2, cause that's 99-00 Si engine
B16A3= Del Slo
B16A3= Del Slo
EIT_certified
17
03-09-2004 05:46 PM
Touch
07-23-2002 11:04 PM
Monty
04-27-2002 08:00 AM
