Any benefits to ARP flywheel bolts?
I saw that they recently came out, but was wondering if there would be any notable differences between OEM and ARP bolts..
i.e. anyone have OEM bolts snap or anything tragic?
Mr. Badwrench
Re: Any benefits to ARP flywheel bolts? (igo4bmx)
when properly torqued, stocks are fine. arp's are good when you are doin like a piece together build. never had any problems with stock flywheel bolts. if you had an engine w/o them, and needed to get a set, then id think about it.
Re: Any benefits to ARP flywheel bolts? (ef9wpb)
Yeah I got some used flywheel bolts , but I think im going to get the arp ones cause of all the hp being made.
All Motor Mentor
1 Post
Re: Any benefits to ARP flywheel bolts? (TurboTeG4)
Stock Honda bolts are adequate for most and power being made in a Honda engine without problem. Arp's are a little stronger than stock which is fine except for the fact that people don't commonly exceed the strength of the stock bolts typically. Do you need them? doubt it. Will you notice a difference? absoulutely not. Will you break the stock flywheel bolts? good luck trying...
angrysmileyface
09-14-2014 05:09 AM
