gsr dash in a 5th gen hatch
i was just wondering if anyone knew how to put a gsr dash in an eg and if its hard to do because id like to know what im getting myself into before i start
Unceasing Measure
Re: gsr dash in a 5th gen hatch (m0t)
If you use the search function in the upper right hand corner of this site you'll find tons of topics and step-by-steps on that very subject. Just type in "GSR dash civic" and click the "archived content" button and you'll be set.
Re: gsr dash in a 5th gen hatch (Archidictus)
yes use the search button.. even if you type "gsr dash" you will find topics about it. From what I've seen, it looks hard, but it comes out great looking
i did it to my civic hatch. and its not hard to put it but just make sure you have everything like the dash the cluster and all the metal brackets that go with it. the only thing hard about is when you get done with it the wiring from the civic fuse to the integra cluster. everthing will work but the blinkers. but what year cluster are you using?
Risky Business
Re: gsr dash in a 5th gen hatch (civicrsx93)
https://honda-tech.com/zerothread?id=504396
https://honda-tech.com/zerothread?id=285567
https://honda-tech.com/zerothread?id=170977
https://honda-tech.com/zerothread?id=458450
http://patriot.net/~merritt/tech.html
https://honda-tech.com/zerothread?id=486442
https://honda-tech.com/zerothread?id=411500
https://honda-tech.com/zerothread?id=401025
https://honda-tech.com/zerothread?id=184743
https://honda-tech.com/zerothread?id=139148
https://honda-tech.com/zerothread?id=94431
i havent gotten a cluster yet im gonna go with all 95 gsr parts and i was reading one of those links it says the door panels dont work so ill need to heat them up is that only type r dash or is that for any integra dash?
does heating them work like i saw in the post cuz they looked pretty mint and if i wanted to heat them would a heat gun get hot enough you think?
Unceasing Measure
Re: (m0t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m0t »</TD></TR><TR><TD CLASS="quote">does heating them work like i saw in the post cuz they looked pretty mint and if i wanted to heat them would a heat gun get hot enough you think?</TD></TR></TABLE>
Yes it will...just be careful not to burn or melt too much of the door. You just need to reshape the contour near the dash/upper left corner of the door so it's flush. Just take your time and it should turn out cherry.
