Need help locating horn wire harness, SRS unit GONE...
I'm in the process of wiring my horn to my MOMO wheel in my 92 Civic and need help locating the horn wire. I'm familiar with the 3-wired yellow harness which usually connects the horn with the SRS unit but the previous owner removed the whole SRS unit which harnessed the horn wire.
I just need help locating the horn wire from another possible place under the dash.
Re: Need help locating horn wire harness, SRS unit GONE... (Lord Helmet)
did he romve the whole harness under the dash, because i dont think you will be able to find the horn wire with out it because its incorporated.
your best bet is to hard wire it straight to the horn.
Re: Need help locating horn wire harness, SRS unit GONE... (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">did he romve the whole harness under the dash, because i dont think you will be able to find the horn wire with out it because its incorporated.
your best bet is to hard wire it straight to the horn.</TD></TR></TABLE>
He did remove the whole harness under the dash. The horn and its wires from the front of the car are still there but they enter a wire loom where which I lose the trace of the wire. I was just wondering if anyone knew which one was the horn wire pre-harness under the dash.
Re: Need help locating horn wire harness, SRS unit GONE... (8point6)
take off your bottom dash cover. you will see a yellow flat wire harness clipped to the middle bottom of the steering colum.. unsnap and you will see numbers on it. #6 is your horn wire... done
Re: Need help locating horn wire harness, SRS unit GONE... (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">take off your bottom dash cover. you will see a yellow flat wire harness clipped to the middle bottom of the steering colum.. unsnap and you will see numbers on it. #6 is your horn wire... done</TD></TR></TABLE>
Thanks for the suggestion, read my first post: this yellow harness is gone. No sarcasm intended.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8point6 »</TD></TR><TR><TD CLASS="quote">
Thanks for the suggestion, read my first post: this yellow harness is gone. No sarcasm intended.</TD></TR></TABLE>
haa haa my bad.... only other way is to hard wire it...goodluck
Re: (Crasian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crasian »</TD></TR><TR><TD CLASS="quote">because I bought my car from some stupid kid </TD></TR></TABLE>
a well know situation.
james2475
Lighting
08-12-2018 11:38 AM
redman223
Audio / Security / Video
07-10-2004 07:34 AM
