Need Help with Check Engine Light / VTEC
Old 06-24-2005, 07:18 AM
springfieldcivic's Avatar
Default Need Help with Check Engine Light / VTEC
I just had my ECU chipped to have the VTEC kick in at 4800 RPMs. When I reach this, the VTEC does kick in, but the check engine light goes on. However, when I turn the car off and start it again, the check engine light is gone.
When my VTEC kicks in, it seems like there is a loss of power. It sounds loud but the car instantly stops accelerating as quickly as it did before the VTEC kicked in. Could the problem be a bad VTEC solenoid?? If it is all in my head and the VTEC is fine, what is the check engine light for??
Old 06-24-2005, 07:48 AM
AutoXer's Avatar
Default Re: Need Help with Check Engine Light / VTEC (springfieldcivic)
https://honda-tech.com/zerothread?id=1171263
What code?
Old 06-24-2005, 08:33 AM
i can't find the gray connector you are talking about to check the ecu
Old 06-24-2005, 08:34 AM
AutoXer's Avatar
Default Re: (springfieldcivic)
It's on the pass side up under the dash, by the kick panel. Did you watch the video that was linked in there?
Old 06-24-2005, 09:54 AM
Default Re: (AutoXer)
yeah i checked and i only found a gray connector up by the a/c wires could that be it?
Old 06-24-2005, 10:48 AM
nvm i found it the code is 21 now what do i do get a new solenoid???
Old 06-24-2005, 11:00 AM
Luserkid's Avatar
Do you have oil?
Old 06-24-2005, 11:28 AM
IHateJDM's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Do you have oil? </TD></TR></TABLE>
if it worked fine before, but not since you lowered vtec, then it's pretty safe to say you are lacking the oil pressure at 4800 rpms that you need for vtec. Did you change anything other than the chip?
Old 06-24-2005, 11:40 AM
it did the same thing before i got the ecu
Old 06-24-2005, 11:42 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by springfieldcivic &raquo;</TD></TR><TR><TD CLASS="quote">it did the same thing before i got the ecu</TD></TR></TABLE>
which ecu are you running? p28?
Old 06-24-2005, 12:54 PM
Default Re: (IHateJDM)
yeah p28 with a skunk2 program
Old 06-24-2005, 01:04 PM
IHateJDM's Avatar
check your wiring.
Solenoid (one wire plug) - A4
Pressure Switch - D6
Pressure Switch Ground - A26, or ground to the head.
If the wiring is good, check the screen in the sensor and make sure its not obstructed.
Old 06-24-2005, 01:19 PM
handa's Avatar
Is your head clicking bad? If so, maybe need a simple valve adjustment due to valve flow.
Old 06-24-2005, 02:10 PM
Default Re: (handa)
a little
but i don't know what a lot is
Old 06-24-2005, 02:14 PM
Electrician
Deemeetree's Avatar
Since no one asked this quesiton, why in the world did you lower VTEC crossover to 4,800 RPM? Have you tuned this engine to completely know that you are making power by switching VTEC to a lower point?
Give us more information about what you have done to your car to determine what went wrong.
As far as "not knowing what a lot is", do a valve adjustment and adjust valve lash to OEM-spec clearances. Then, you'll at least know it's not that.
Old 06-24-2005, 02:26 PM
Default Re: (Deemeetree)
I have an intake, exhaust, header, and Hotwires
but I have ordered cam and gear, intake manifold and fuel rail, msd ignition, underdrive pulley, and VAFC
92accordh22a
12-17-2006 12:05 AM
si90rex
07-05-2006 03:12 PM
veilsides2000
11-27-2004 11:18 PM
grlstockb18c1
11-03-2004 07:07 PM
inzaneN1
12-03-2003 01:34 AM
Quick Reply: Need Help with Check Engine Light / VTEC
