Transmission....
Transmission....
I was driving my Civic today, just normal not beating on it then all of a sudden it got really hard to shift.....is that my transmission? Pressure Plater possibly? Any feed back would be much appreciated......
Re: Transmission.... (wheels01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheels01 »</TD></TR><TR><TD CLASS="quote">define hard to shift? Resistance? grinding?</TD></TR></TABLE>
x2
x2
Re: Transmission.... (Zero4488)
maybe a shifter linkage problem? get under there and look is my suggestion... if that's not the problem, then yeah you're probably looking at something serious.
Electrician
Re: (B16aDasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher »</TD></TR><TR><TD CLASS="quote">Check master cylinder, and slave master cylinder.</TD></TR></TABLE>
It's Clutch Master Cylinder and Slave Cylinder. You're negating the "master" part when you say "slave master cylinder".
Plus, he said the shifter linkage fell off. It has nothing to do with the clutch cylinders.
Re: (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">It's Clutch Master Cylinder and Slave Cylinder. You're negating the "master" part when you say "slave master cylinder".
Plus, he said the shifter linkage fell off. It has nothing to do with the clutch cylinders.</TD></TR></TABLE>
oops i meant master cylinder and slave cylinder. My car had the same problem. IT was the master cylinder. So this problem CAN deal with the master cylinder.
Electrician
Re: (B16aDasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher »</TD></TR><TR><TD CLASS="quote">oops i meant master cylinder and slave cylinder. My car had the same problem. IT was the master cylinder. So this problem CAN deal with the master cylinder.</TD></TR></TABLE>
Didn't say that it wasn't. But:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zero4488 »</TD></TR><TR><TD CLASS="quote">Yea, It turns out it was the shift linkage.....now it's hanging from the bottom of my car.....</TD></TR></TABLE>
