b16 mess HELP
b16 mess HELP
i just did my motor swap and i had a few problems with her. at first vtec wouldnt crack but i fixed that, then the car wouldnt start i thought it was the starter but it still cranks over after i push start it when the car is on,then my guages went out, the temp gauge still goes to HOT :thumbdown, and then i have a rough idle it goes up and down and then at times stays at 1,300 rpm HELP!!!
Re: b16 mess HELP (2ner12sec)
WHATS UP HAVE YOU FIXED THE STARTING UP PROBLEM IF YOU HAVENT MAKE SURE THAT ALL THE GROUND CABELS ON THE MOTOR ARE ON CHECK TWICE. IS YOU CAR THROWING ANY CODES FOR THE IDLE PROBLEM. NEED TO KNOW THE CODE IT COULD BE THE TPS SENSOR, IAC SENSOR. IF YOU NEED MORE HELP IM ON AIM EMBIDIA1 IS MY SCREEN NAME
5thgen4dr
10-30-2006 03:36 PM
ay_dawg
09-20-2006 01:56 PM
one slow coupe
12-24-2005 04:49 PM
NikoZai
08-30-2002 12:34 AM
