B16a2, Compression after milling and 2 resurfaces? Clearance issue?
Heya, Im gonna buy a b16a2 pretty damn soon. I want to have the bottom end stock, with my SI head and stage 2's. I've had couple built motors before this so i had my had milled the first time, and it's been resurfaced once. The head has been laying around so im gonna get it resurfaced again.
SO how high do u think my CR is? Im not exactly sure how much they take off of the head when they resurface it, but im guessing my CR will be around 10.8?(stock 10.2) Im actually more concerned about clearance then anything, don't want anything slapping. Here's the kicker, im gonna take the stock head off the b16a2 cus it's stock. My head (also SI) I have in the garage has valve-train, so i could pay someone switch out the valve-train into the Non-milled head. IDK, what do u guys think. I know this was long but thanks for the help, it's appreciated! -Jeff
Re: B16a2, Compression after milling and 2 resurfaces? Clearance issue? (Punker1234)
the're gonna measure it first to see if it needs it, its not gonna raise it up that high anyways. you'd have to take off alot more than that. and you wont have any clearence issues.
Re: B16a2, Compression after milling and 2 resurfaces? Clearance issue? (jdmhonda)
what u mean they measure it? they have to resurface it, it's be laying around face up, what whatever was ont he ground coulda dented it etc etc. how much compression do u think it will be? any ideas?
when you have it milled its not even in the mm range compression and clearance should not be a factor - remember to clay your motor !
http://www.c-speedracing.com has a compression calculator . and a tutorial how to clay your motor those two things added together and done properly and you will be fine !
