how do you take out the climate control from the eks?
Electrician
Once the cig console is out remove the climate console. there is a cable that goes from the climate to the heater core bottom, trace is and remove it from the pin and holder. find the two screws in the front bottom of the climate metal shell and remove those. remove the hazard and defroster buttons carefully using a pin screw driver and there is a screw behind each button. remove the radio and unplug everything from the climate control. find any screws left and by now you should be able to carefully pop off the climate bezel.
i guess i'll do that lol
Re: (ner0x)
That sounds like the '96-'98 one, am I wrong?
The 99-00 climate control is electronic all you have to do is take out those 2 screws, and then undo like 3 or 4 wiring harnesses.
Re: (eg6coupe)
on 99-00 civic climate control theres 2 screws under then pull cover off then under there is 4 more screws under that.. then pull it out hope that helps
Sinner
01-23-2006 07:45 AM
