y7 to y8 manifold swap (quick question)
First off, can I use either a y7 or y8 intake mani gasket, does it matter?
Also I have a 5spd y8 mani, I cant seem to find a wiring diagram for the 2 wire IAVC. My question is this, is it easier to use the y7 tb and swap everything(rotor, spring) from the y8 tb onto the y7 so I can use the y7 IAVC, then just block off the y8 mani IAVC holes
or
splice and dice to fit the 2 wire IAVC?
Also what is commonly used to block off the 2 wire IAVC holes if the y7 th is used?
TIA
or
TIA
Re: (drewboy)
so your car is automatic, you need to use your 3 wire IACV or you will have idleing problems, need to swap your tb over, and you may have to block off the 5 speed IACV if its is normaly open (not sure on this, use jb weld if you must)
you can't use a 3 wire ecu on a 2 wire iacv and vise versa
uindaway
11-12-2012 01:25 AM
SPOON_BeIgHtEeNsEe
09-25-2003 03:03 PM
SPOON_BeIgHtEeNsEe
01-21-2003 06:50 AM
