should i use a 99 si brake master cylinder or get the correct one?
I have a 99 si brake master cylinder which has the brake lines on the opposite side of my 93 civic, should i go get the correct one for the 93 or should i just bend the brake lines to fit the 99 cylinder? i have the brake booster also since the mc is in a completely different posistion also mounting. Any downsides? car has no abs, came from the factory with rear disks.
Re: should i use a 99 si brake master cylinder or get the correct one? (BlueIntegraBoy)
i just want something that works, i dont care if its the stock one or not (my moms car) im just wondering if i should just go get the correct one or use the one i have and hope i can bend the lines.
whats the point of having a bigger brake master cylinder? and brake booster?? sorry im a noob
Re: should i use a 99 si brake master cylinder or get the correct one? (infinkc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinkc »</TD></TR><TR><TD CLASS="quote">i just want something that works, i dont care if its the stock one or not (my moms car) im just wondering if i should just go get the correct one or use the one i have and hope i can bend the lines.</TD></TR></TABLE>
Go get a correct one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harley06 »</TD></TR><TR><TD CLASS="quote">whats the point of having a bigger brake master cylinder? and brake booster?? sorry im a noob</TD></TR></TABLE>
If you have larger brakes, you need more pressure.
if that's the case why are you even asking this question. common sense would be just get the exact replacement.
Re: should i use a 99 si brake master cylinder or get the correct one? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
if that's the case why are you even asking this question. common sense would be just get the exact replacement.</TD></TR></TABLE>
casue i have the si one already, if i can use the one i have why bother and buy a different one.
Decided to use the 99 si one instead of buying the correct one, if anyone is wondering this is a picture of how i bent the brake lines going to the master cylinder, it wasnt a very hard thing to do at all.
lollypopking
01-16-2005 09:51 PM
